Tables in CCM0300 and ART database
Can any one provide a link to cisco document that gives a brief description about the tables in CCM0300 and ART databases with respect to CCM 4.3
Re: Tables in CCM0300 and ART database
There isn't any document on that.
The data dictionaries started with 5.X as the DB was locked down and you couldn't browse it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for the reply Java, but i am able to browse the tables in CCM0300 and ART in CCM 4.3. Actually i want to extract some information for making a customized billing software.
Yes, that's my point. As I mentioned before, the data dictionaries are for the Linux appliances were you CAN'T browse.
You can use the one from 5.X, there will be different fields but the basic structure is still quite similar.
The only other option is to reach the DEV team and ask for their assistance, they probably have/had something like this or can greatly assist in creating your custom billing SW.
java
java
222
