Bronze
Tail End Hopoff
Does anyone know where I can find a basic (and preferably free) listing of which area codes are local to which other area codes? We're looking at tail-end hopoff and I can't find a good listing of which area codes besides the explicit ones to route out remote gateways (for example, I know a call to 913 from Nevada should be routed out the Kansas City router, but 816 is also local and should also be sent out the KC router).
Jim
1 ACCEPTED SOLUTION
Silver
Re: Tail End Hopoff
This is what I use:
http://www.localcallingguide.com/
For you, I would go to:
http://www.localcallingguide.com/lprefix.php?exch=064370&dir=1
That has all local calling for Kansas City, KS.
Lelio
Silver
Re: Tail End Hopoff
This is what I use:
Lelio
Bronze
Re: Tail End Hopoff
Outstanding, thank you very much for the quick response, this appears to be exactly what I need.
Jim
Silver
Re: Tail End Hopoff
No problem, hope it helps.
102
