Tandberg Video Endpoints with CCM 4.1.3 sr6a
Hello all !! Hope everyone is well !!!
I am in the middle of rolling out a video conferencing solution for our company using Tandberg video endpoints and Tandberg back-end infrastructure with CCM 4.1.3 sr6a. Currently I have all Tandberg video endpoints registered to CCM as H.323 client with no Gatekeeper and all back-end infrastructure devices (MCU, IP Gateway, and ISDN Gateway) configured in CCM as H.323 Gateway and I noticed there is a noticeable difference in video quality when dialing between Tandberg endpoints by IP address verses dialing by 4-digit extension. Video quality is much better when dialing by IP address.
Has anyone run into this type issue ? Are there any workaround ? and below are some questions that I have.
- I would like to find out why the video quality was poor when dialing by 4-digit extension between H.323 client endpoints vs direct dial by IP address ?
- I would like to find out if CCM 4.1.3 support H.264 call between two H.323 client endpoints ?
- Do I need a Gatekeeper for H.264 call between two H.323 client endpoints ?
- Does CCM 6.x support H.264 between H.323 client endpoints ?
thank you very much in advance !! any suggestions / inputs is highly appreciated !!!
Danny
1 REPLY
Re: Tandberg Video Endpoints with CCM 4.1.3 sr6a
I'm not sure about the codecs... One thing you can check is the video bandwidth that you've specified in the Region and Locations configuration of your CUCM.
Best regards,
Stoyan
121
