Community Member
TAPI/TSP on Terminal Server with CUCME
Hi all,
We have a customer who moves a CRM application on a terminal server.
The CRM communicates with the CUCME through TAPI (CME_TSP.exe).
Unfortunately, the Cisco CME_TSP can handle only one TSP-connection with the CUCME on a single local pc/server.
Who knows a 3party software or workaround to setup more than one TAPI connection (multiple sessions with the own TAPI connection) on the Microsft 2008 Terminal server.
Norbert
1 REPLY
Silver
Re: TAPI/TSP on Terminal Server with CUCME
There is only one TAPI instance supported per ephone. It is not possible to install more that one TSP on a Client or Server. With the addition of the CTI Manager, a single TSP will be able to control devices on different CCM in a cluster.
302
