TAPS - installation error
cjrchoi11
I have CUCM7.0 and want to install TAPS applicaiton in UCCX5.0.2 box but I got the below error message.
"Error opening installation log file. Verify that the specified log file location exists and is writable"
Advise please,
Tommer Catlin
Did you figure this out? Im getting the same error message.
Tommer Catlin
I figured it out.. I think the file is broken. I unpacked the file exe file into a folder. I then ran the ISSScript.exe first, then I ran the setup.exe and it worked fine.
Thanks a lot for figuring it out and sharing with us.
Cheers,
Bala.
Cheers,
Bala.
