TCL Auto Attendant Problem
Hi Guys,
I have here in this case a business edition 3000 with a sip trunk to CUBE.I had to configuire BACD to meet the requirements of the customer which BE3000 does not support.
The trunk is configured on BE to send the call to CUBE IP address if some one dials 750 which is the pilot number of Auto Attened script.
when i try to dial 750 i hear nothing.As i understand service should be invoked on the inbound dial-peer,i configured destination pattern with the same aa pilot and session target with the ip address of FA0/4 (public ip address of cube) ,tried a loopback address and default gateway ip address of BE 3000 which is an ip address also in CUBE ,but i never hear anything.In my understanding the outbound dial-peer shoildn't be the reason cause I care about the inbound only in the auto attendant case !
Here are sample configurations with debugs of voip dialpeer and ccsip messages :
CUBE(config)#do show run | s application|dial-peer voice 750 voip
application
service autoattend flash:/its-CISCO.2.0.2.0.tcl
  paramspace english language en
  paramspace english index 0
  param aaPilot 750
  paramspace english location flash:/
  paramspace english prefix en
  param oprtr 100
global
  service alternate default
service autoattend
destination-pattern 750
session target ipv4:10.41.201.250
incoming called-number 750
CUBE#show call application sessions
Session ID 3E
            App: autoattend
           Type: Service
            Url: flash:/its-CISCO.2.0.2.0.tcl
Session ID 3F
            App: autoattend
           Type: Service
CUBE(config)#do terminal monitor
CUBE(config)#exit
CUBE#
Jul 23 10:50:18.939: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=750, Called Number=750, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=750
   Result=Success(0) after DP_MATCH_DEST
Jul 23 10:50:18.939: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=750, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Jul 23 10:50:18.939: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=750
Jul 23 10:50:18.939: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8124XXXXXX, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jul 23 10:50:18.943: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 23 10:50:18.943: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 23 10:50:18.943: //-1/A89C56800000/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8124XXXXXX, Called Number=750, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=750
Jul 23 10:50:18.943: //-1/A89C56800000/DPM/dpMatchSafModulePlugin:
Jul 23 10:50:18.947: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 23 10:50:18.947: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 23 10:50:18.951: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=750, Peer Info Type=DIALPEER_INFO_SPEECH
Jul 23 10:50:18.951: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=750, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jul 23 10:50:18.951: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 23 10:50:18.951: //-1/A89C56800000/DPM/dpMatchPeersCore:
CUBE#Match Rule=DP_MATCH_DEST_URI; URI=sip:750@fa0/4:5060
Jul 23 10:50:18.955: //-1/A89C56800000/DPM/dpMatchSafModulePlugin:
Jul 23 10:50:18.955: //-1/A89C56800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
CUBE(config)#do debug ccsip messages
SIP Call messages tracing is enabled
Jul 23 11:02:45.407: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:750@fa0/4ip:5060 SIP/2.0
Via: SIP/2.0/TCP 10.41.201.250:5060;branch=z9hG4bK40b5a7c0e11a7
From: <sip:8124XXXXXX@10.41.201.250>;tag=3994346~77bba026-5b79-4e2a-a90d-bffd1d2afd15-26930118
To: <sip:750@fa0/4ip>
Date: Tue, 23 Jul 2013 11:02:45 GMT
Call-ID: 65db7e00-1ee162d5-198be-fac9290a@10.41.201.250
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:10.41.201.250:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1708883456-0000065536-0000000114-4207487242
Session-Expires:  1800
P-Asserted-Identity: <sip:8124XXXXXX@10.41.201.250>
Remote-Party-ID: <sip:8124XXXXXX@10.41.201.250>;party=calling;screen=yes;privacy=off
Contact: <sip:8124XXXXXX@10.41.201.250:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
Jul 23 11:02:45.423: //3600/65DB7E000000/SIP/Msg/ccsipDisplayMsg:
Sent:
CUBE(config)#SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.3.1.T
Content-Length: 0
CUBE(config)#
CUBE(config)#
Jul 23 11:03:05.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:fa0/4ip:5060 SIP/2.0
Via: SIP/2.0/TCP 10.41.201.250:5060;branch=z9hG4bK40b64c63c9c0
To: <sip:fa0/4ip>
Date: Tue, 23 Jul 2013 11:03:05 GMT
Call-ID: 71c74000-1ee162e9-198c1-fac9290a@10.41.201.250
CSeq: 101 OPTIONS
Contact: <sip:10.41.201.250:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Jul 23 11:03:05.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:fa0/4ip>;tag=26CB3BA4-1974
CSeq: 101 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Accept: application/sdp
Supported: 100rel,timer,resource-priorit
CUBE(config)#y,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 380
v=0
o=CiscoSystemsSIP-GW-UserAgent 9576 629 IN IP4 fa0/4ip
s=SIP Call
c=IN IP4 fa0/4ip
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 fa0/4ip
m=image 0 udptl t38
c=IN IP4 fa0/4ip
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
CUBE(config)#
Jul 23 11:03:56.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:750@fa0/4ip:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
Jul 23 11:03:56.191: //3600/65DB7E000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 23 Jul 2013 11:03:56 GMT
CSeq: 101 CANCEL
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:750@\fa0/4ip>;tag=26CC00AC-667
CSeq: 101 INVITE
Reason: Q.850;cause=16
Content-Length: 0
Jul 23 11:03:56.195: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:750@fa0/4ip:5060 SIP/2.0
To: <sip:750@fa0/4ip>;tag=26CC00AC-667
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thanks in advance !
Dear folk,
Let try aa-pilot
application
  param aa-pilot 750
  param oprtr 100
and under voip dial-peer 750, add:
codec g711ulaw
for tracking: debug voice application script
Re: TCL Auto Attendant Problem
Dear Lan Pham.
Thanks for your reply ,first i didn't think that the aa-pilot instead of aapilot would make difference cause the param aapilot i copied it as it was written in the script.
But i changed it and also was changing some config's in the dialpeer step by step but i still hear nothing.
Here are the configs and the debug of voice application script:
CUBE#debug voice application script
voip application script debugging is on
CUBE#
Jul 24 07:22:58.162: //4872//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
ANI
DNIS sip:750@fa0/4_public_ip_of cube:5060
Jul 24 07:22:58.190: //4872//TCL :/tcl_PutsObjCmd:
Call failed. Play prompt and collect digit
proc act_Select
proc act_DestBusy
CUBE#
application
param aa-pilot 750
param oprtr 100
global
service autoattend
session protocol sipv2
dtmf-relay rtp-nte sip-kpml sip-notify h245-signal h245-alphanumeric
codec g711ulaw
no vad
I had a voice class codec and i added to the dial-peer instead of only g711ulaw but didn't make difference.
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
When i use debug ccsip messages it shows 404 not found and i understand this is because 750 is just a pilot number.
Could this be  a problem with my voice files,cause for only one time instead of hearing nothing ,i heared some distorted sound.
Thanks in advance
Hi, please get back with the log of:
debug voip application tclcommands
Hi Ahmed.
Try also to reload audio prompt by using audio-promt load flash:filename.au command
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo,already tried,does not work.
Do i need to reload the router ?
Hi Ahmed.
Yes in some case a reload could be useful
I had similar issues in the past with promts and a reload solved the problem
Can you please tell me the IOS version you are using?
Carlo
Hi Paolo,thanks for reply
here is the version:
Cisco IOS Software, C880 Software (C880VOICE-UNIVERSALK9_NPE-M), Version 15.3(1)T, RELEASE SOFTWARE (fc1)
Hi ,thanks for reply.
When i load the autoattend service ,i get connected to the pilot but i hear a destored sound not a sound of human,and when i try to interrupt this sound by dailing internal number the debug dialpeer shows that it collects 2 digits only of 3 digits internal number.
CUBE#show debug
debug voip application script is ON (filter is OFF)
debug voip application tcl commands is ON (filter is OFF)
CUBE#call application voice load autoattend
CUBE#
Jul 24 11:45:15.225: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=8073, url=flash:/its-CISCO.2.0.2.0.
tcl
Jul 24 11:45:15.225: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x8C2E48C0
Jul 24 11:45:15.225: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x8C2E48C0
Jul 24 11:45:15.225: //-1//AFW_:EE8A18AF7C000:/Tcl_Link: Linking script autoattend
Jul 24 11:45:15.229: //-1//TCL :EE8A18AF7C000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 24 11:45:15.229: //-1//TCL :EE8A18AF7C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 24 11:45:15.229: //-1//TCL :EE8A18AF7C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 24 11:45:15.229: //-1//AFW_:EE8A18AF7C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 11:45:15.229: //-1//TCL :EE8A18AF7C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 24 11:45:15.233: //-1//AFW_:EE8A18AF7C000:/vtr_cf_avpair: argc 3 argindex 2
Jul 24 11:45:15.233: //-1//PACK:EE8A18AF7C000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 24 11:45:15.233: //-1//AFW_:EE8A18AF7C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 24 11:45:15.233: //-1//PACK:EE8A18AF7C000:/tcl_ParamReadObjCmd:  operator
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 24 11:45:15.233: //-1//TCL :EE8A18AF7C000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 24 11:45:15.233: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 24 11:45:15.233: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 24 11:45:15.233: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 24 11:45:15.233: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 24 11:45:15.233: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 24 11:45:15.233: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 24 11:45:15.233: FSM start state CALL_INIT(1)
CUBE#
Jul 24 11:45:15.233: //-1//AFW_:EE8A18AF7C000:/Tcl_Link: Script autoattend succesfully linked.
CUBE#
Jul 24 11:46:53.393: //-1//AFW_:EE8A18B064000:/Tcl_Link: Linking script autoattend
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 24 11:46:53.401: //-1//AFW_:EE8A18B064000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 24 11:46:53.401: //-1//AFW_:EE8A18B064000:/vtr_cf_avpair: argc 3 argindex 2
Jul 24 11:46:53.401: //-1//PACK:EE8A18B064000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 24 11:46:53.401: //-1//TCL :EE8A18B064000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 24 11:46:53.401: //-1//PACK:EE8A18B064000:/tcl_ParamReadObjCmd:  operator
Jul 24 11:46:53.405: //-1//TCL :EE8A18B064000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 24 11:46:53.405: //-1//TCL :EE8A18B064000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 24 11:46:53.405: //-1//TCL :EE8A18B064000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 24 11:46:53.405: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 24 11:46:53.405: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 24 11:46:53.405: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 24 11:46:53.405: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 24 11:46:53.405: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 24 11:46:53.405: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 24 11:46:53.405: FSM start state CALL_INIT(1)
Jul 24 11:46:53.405: //-1//AFW_:EE8A18B064000:/Tcl_Link: Script autoattend succesfully linked.
Jul 24 11:46:53.405: //5269//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 24 11:46:53.409:
Jul 24 11:46:53.409: //5269//TCL :/tcl_PutsObjCmd:
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 24 11:46:53.409: //5269//AFW_:/vtr_lg_ani: argc 2 argindex 2
ANI sip:8124XXXXXX@10.41.201.250
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 24 11:46:53.409: //5269//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 24 11:46:53.409: //5269//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 24 11:46:53.409: //5269//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 24 11:46:53.409: //5269//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 24 11:46:53.409: //5269//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 24 11:46:53.409: //5269//AFW_:/vtd_lg_incoming: argc 2
Jul 24 11:46:53.409: //5269//AFW_:/vtd_lg_incoming: Legs [5269 ]
Jul 24 11:46:53.409: //5269//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 11:46:53.409: //5269//TCL :/tcl_LegObjCmd:  leg setup sip:750@fa0/4_public_ip_of cube:5060 callInfo leg_incoming
Jul 24 11:46:53.409: //5269//AFW_:/vtd_lg_incoming: argc 4
Jul 24 11:46:53.409: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 24 11:46:53.413: //5269//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 24 11:46:53.413: //5269//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 24 11:46:53.413: //5269//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 24 11:46:53.413: //5269//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 24 11:46:53.413: //5269//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 24 11:46:53.413: //5269//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 24 11:46:53.413: //5269//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 24 11:46:53.413: //5269//AFW_:/vtd_lg_incoming: argc 2
Jul 24 11:46:53.413: //5269//AFW_:/vtd_lg_incoming: Legs [5269 ]
Jul 24 11:46:53.413: //5269//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 11:46:53.413: //5269//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 24 11:46:53.413: //5269//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 24 11:46:53.417: //5269//AFW_:/vtd_lg_incoming: Legs [5269 ]
Jul 24 11:46:53.417: //5269//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 11:46:53.417: //5269//TCL :/tcl_PutsObjCmd:
proc act_Select
Jul 24 11:46:53.417: //5269//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1 pattern
Jul 24 11:46:53.417: //5269//AFW_:/vtd_lg_incoming: argc 4
proc act_DestBusy
Jul 24 11:46:53.417: //5269//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 24 11:46:53.417: //5269//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 24 11:46:53.417: //5269//AFW_:/vtd_lg_incoming: argc 3
Jul 24 11:46:53.417: //5269//PACK:/Media_Play_Start:
Jul 24 11:46:53.417: //5269//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 24 11:46:53.417: //5269//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
CUBE#
Jul 24 11:48:23.517: //5269//TCL :/tcl_CallObjCmd:  call close
Jul 24 11:48:23.517: //5269//TCL :/tcl_CallCloseObjCmd:  close
Hi Ahmed
In fact, I dont see your script play some media like "welcome" or something.
Could you share your tcl script here??
Hi Lan Pham,
thanks again for reply.
I attached the tcl script.Take a look please.
Thanks.
Ok Ahmed.
I tryed with the same platform/Ios in my lab.
A reload sloved the issue
Try to reload and let me know
Carlo
ok,i can't make this now cause this is a client's working network.I ll try to do this late at night,and will update you tomorrow.
Thanks Carlo for reply.
Hi Carlo,
the reload didn't resolve the issue.I still hear distorted sound, also once i hang up the script disconnect by itself and the phone displays enter number and waiting for more digits.I have to reload the script to hear the distorted sound again and see on the phone's screen (connected )
Thanks.
Hi Ahmed
I revised one command line on your script:
"media play leg_incoming _welcome.au %s100 _enter_dest.au"
Make sure "en_welcome.au" and "en_enter_dest.au" seat in flash:/
let upload the attachment to CME, reload and test again, if you see:
Jul 24 13:57:17.850: //27//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1
Jul 24 13:57:17.850: //27//AFW_:/vtd_lg_incoming: argc 3
Jul 24 13:57:17.850: //27//AFW_:/vtd_lg_incoming: Legs [27 ]
Jul 24 13:57:17.850: //27//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 13:57:17.854: //27//PACK:/tcl_MediaObjCmd:  media play leg_incoming _holidaynotice1.au %s100
_enter_dest.au
Jul 24 13:57:17.854: //27//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _welcome.au %s100 _enter_dest.au
       Means your script is running well.
If you see above but still can not hear anything, codec issue shoulde be accounted
Hi Lan,thanks for your effort and time.
I uploaded the script that you have edited and even used different audio files but i still receiving a distorted sound that doesn't mean anything.I tried to use different codecs but the only one that's gives me at least distorted sound is g711ulaw.
Here is the debug output:
CUBE#
Jul 24 19:55:31.903: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=8065, url=flash:/its-CISCO.2.0.2.0.tcl
Jul 24 19:55:31.903: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x8BD30620
Jul 24 19:55:31.903: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x8BD30620
Jul 24 19:55:31.903: //-1//AFW_:EE89AA093C000:/Tcl_Link: Linking script autoattend
Jul 24 19:55:31.907: //-1//TCL :EE89AA093C000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 24 19:55:31.911: //-1//AFW_:EE89AA093C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 24 19:55:31.911: //-1//AFW_:EE89AA093C000:/vtr_cf_avpair: argc 3 argindex 2
Jul 24 19:55:31.911: //-1//PACK:EE89AA093C000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 24 19:55:31.911: //-1//PACK:EE89AA093C000:/tcl_ParamReadObjCmd:  operator
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 24 19:55:31.911: //-1//TCL :EE89AA093C000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 24 19:55:31.915: //-1//TCL :EE89AA093C000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 24 19:55:31.915: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:31.915: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 24 19:55:31.915: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:31.915: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:31.915: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 24 19:55:31.915: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 24 19:55:31.915: FSM start state CALL_INIT(1)
CUBE#
Jul 24 19:55:31.915: //-1//AFW_:EE89AA093C000:/Tcl_Link: Script autoattend succesfully linked.
CUBE#
CUBE#
CUBE#
CUBE#
CUBE#
CUBE#
CUBE#
Jul 24 19:55:45.971: //-1//AFW_:EE89AA0A24000:/Tcl_Link: Linking script autoattend
Jul 24 19:55:45.975: //-1//TCL :EE89AA0A24000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 24 19:55:45.975: //-1//TCL :EE89AA0A24000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 24 19:55:45.975: //-1//TCL :EE89AA0A24000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 24 19:55:45.975: //-1//AFW_:EE89AA0A24000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 19:55:45.975: //-1//TCL :EE89AA0A24000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 24 19:55:45.979: //-1//AFW_:EE89AA0A24000:/vtr_cf_avpair: argc 3 argindex 2
Jul 24 19:55:45.979: //-1//PACK:EE89AA0A24000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 24 19:55:45.979: //-1//AFW_:EE89AA0A24000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 24 19:55:45.979: //-1//PACK:EE89AA0A24000:/tcl_ParamReadObjCmd:  operator
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 24 19:55:45.979: //-1//TCL :EE89AA0A24000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 24 19:55:45.979: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:45.979: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 24 19:55:45.979: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:45.979: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 24 19:55:45.979: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 24 19:55:45.979: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 24 19:55:45.979: FSM start state CALL_INIT(1)
Jul 24 19:55:45.979: //-1//AFW_:EE89AA0A24000:/Tcl_Link: Script autoattend succesfully linked.
Jul 24 19:55:45.983: //8//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 24 19:55:45.983: //8//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 24 19:55:45.983: //8//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 24 19:55:45.983: //8//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 24 19:55:45.983: //8//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 24 19:55:45.987: //8//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 24 19:55:45.987: //8//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 24 19:55:45.987: //8//AFW_:/vtd_lg_incoming: argc 2
Jul 24 19:55:45.987: //8//AFW_:/vtd_lg_incoming: Legs [8 ]
Jul 24 19:55:45.987: //8//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 19:55:45.987: //8//TCL :/tcl_LegObjCmd:  leg setup sip:750@fa0/4_public_ip_of cube:5060 callInfo leg_incoming
Jul 24 19:55:45.987: //8//AFW_:/vtd_lg_incoming: argc 4
Jul 24 19:55:45.987: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 24 19:55:45.991: //8//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 24 19:55:45.991: //8//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 24 19:55:46.011: //8//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 24 19:55:46.011: //8//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 24 19:55:46.011: //8//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 24 19:55:46.011: //8//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 24 19:55:46.011: //8//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 24 19:55:46.011: //8//AFW_:/vtd_lg_incoming: argc 2
Jul 24 19:55:46.011: //8//AFW_:/vtd_lg_incoming: Legs [8 ]
Jul 24 19:55:46.011: //8//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 19:55:46.011: //8//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 24 19:55:46.011: //8//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 24 19:55:46.011: //8//TCL :/tcl_PutsObjCmd:
proc act_Select
Jul 24 19:55:46.011: //8//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1 pattern
Jul 24 19:55:46.011: //8//AFW_:/vtd_lg_incoming: argc 4
Jul 24 19:55:46.015: //8//TCL :/tcl_PutsObjCmd:
proc act_DestBusy
CUBE#
Jul 24 19:55:46.015: //8//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 24 19:55:46.015: //8//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 24 19:55:46.015: //8//AFW_:/vtd_lg_incoming: argc 3
Jul 24 19:55:46.015: //8//AFW_:/vtd_lg_incoming: Legs [8 ]
Jul 24 19:55:46.015: //8//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 24 19:55:46.015: //8//PACK:/Media_Play_Start:
Jul 24 19:55:46.015: //8//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 24 19:55:46.015: //8//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
Also once i hang up the script disconnect by itself and the phone  displays enter number and waiting for more digits.I have to reload the  script to hear the distorted sound again and see on the phone's screen  (connected )
Thanks in advance
Hi Ahmed,
Based on your output, infact , your script has never played "_welcome.au" for you to hear, the call failed immediately as the aa  catched the incoming call
"Call failed. Play prompt and collect digit"
Let try the attached script with same parameter. then show me the output of debug
Besides, please let me know what debug command you used to have such above ouput?? (except "debug voice application script")
Thank you so much for your help.
unfortunately it didn't work.This is a CUBE (cisco unified border element) may be that is the reason !
I am using three commands:
OUTPUT:
CUBE#
Jul 25 14:00:55.767: //-1//AFW_:EE89AC4FFC000:/Tcl_Link: Linking script autoattend
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 25 14:00:55.775: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 25 14:00:55.775: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair: argc 3 argindex 2
Jul 25 14:00:55.775: //-1//PACK:EE89AC4FFC000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 25 14:00:55.775: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 25 14:00:55.775: //-1//PACK:EE89AC4FFC000:/tcl_ParamReadObjCmd:  operator
Jul 25 14:00:55.779: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists max-extension-length
Jul 25 14:00:55.779: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists max-extension-length
Jul 25 14:00:55.779: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 25 14:00:55.779: //-1//TCL :EE89AC4FFC000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 25 14:00:55.779: //-1//TCL :EE89AC4FFC000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 25 14:00:55.779: //-1//TCL :EE89AC4FFC000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 25 14:00:55.779: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 25 14:00:55.779: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 25 14:00:55.779: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 25 14:00:55.779: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 25 14:00:55.779: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 25 14:00:55.779: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 25 14:00:55.779: FSM start state CALL_INIT(1)
Jul 25 14:00:55.779: //-1//AFW_:EE89AC4FFC000:/Tcl_Link: Script autoattend succesfully linked.
Jul 25 14:00:55.783: //1109//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 25 14:00:55.783: //1109//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 25 14:00:55.783: //1109//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 25 14:00:55.783: //1109//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 25 14:00:55.783: //1109//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 25 14:00:55.783: //1109//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 25 14:00:55.783: //1109//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 25 14:00:55.783: //1109//AFW_:/vtd_lg_incoming: argc 2
Jul 25 14:00:55.783: //1109//AFW_:/vtd_lg_incoming: Legs [1109 ]
Jul 25 14:00:55.783: //1109//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 14:00:55.783: //1109//TCL :/tcl_LegObjCmd:  leg setup sip:750@fa0/4_public_ip_of cube:5060 callInfo leg_incoming
Jul 25 14:00:55.783: //1109//AFW_:/vtd_lg_incoming: argc 4
Jul 25 14:00:55.787: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 25 14:00:55.787: //1109//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 25 14:00:55.787: //1109//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 25 14:00:55.811: //1109//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 25 14:00:55.811: //1109//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 25 14:00:55.811: //1109//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 25 14:00:55.811: //1109//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 25 14:00:55.811: //1109//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 25 14:00:55.811: //1109//AFW_:/vtd_lg_incoming: argc 2
Jul 25 14:00:55.811: //1109//AFW_:/vtd_lg_incoming: Legs [1109 ]
Jul 25 14:00:55.811: //1109//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 14:00:55.811: //1109//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 25 14:00:55.811: //1109//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 25 14:00:55.811: //1109//TCL :/tcl_PutsObjCmd:
proc act_Select
Jul 25 14:00:55.811: //1109//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1
Jul 25 14:00:55.811: //1109//AFW_:/vtd_lg_incoming: argc 3
proc act_DestBusy
Jul 25 14:00:55.815: //1109//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 25 14:00:55.815: //1109//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 25 14:00:55.815: //1109//AFW_:/vtd_lg_incoming: argc 3
CUBE#
Jul 25 14:00:55.815: //1109//AFW_:/vtd_lg_incoming: Legs [1109 ]
Jul 25 14:00:55.815: //1109//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 14:00:55.815: //1109//PACK:/Media_Play_Start:
Jul 25 14:00:55.815: //1109//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 25 14:00:55.815: //1109//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
Jul 25 14:01:14.719: //1109//TCL :/tcl_CallObjCmd:  call close
Jul 25 14:01:14.719: //1109//TCL :/tcl_CallCloseObjCmd:  close
Thanks for help.
Hi Ahmed,
The weird thing here is the script behaves as if it received an invalid DNIS information very soon and resulted in call fail.
I customized the script that allow to re-enter the extension number after the 1st attempt to put ext fail,  and the expected audio is "... the number you called is unreachable.." and prompt you to input ext.
Otherwise, please take the output of "debug voice dial-peer inout"
Hi Lan,nothing the same destorted sound just this time to stop this sound i started to dial internal number 101,this time the script tokk from me the three digits not 2 digits like before but the phone shows connected on the screen while i waited about 5 minutes but didn't hear the  i connected to 101.
Here are the same debugs like before plus debug voip dialpeer inout:
ul 25 17:09:38.318: //-1//AFW_:EE89AC46EC000:/Tcl_Link: Linking script autoattend
Jul 25 17:09:38.322: //-1//TCL :EE89AC46EC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 25 17:09:38.322: //-1//TCL :EE89AC46EC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 25 17:09:38.322: //-1//AFW_:EE89AC46EC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 25 17:09:38.322: //-1//TCL :EE89AC46EC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 25 17:09:38.326: //-1//AFW_:EE89AC46EC000:/vtr_cf_avpair: argc 3 argindex 2
Jul 25 17:09:38.326: //-1//PACK:EE89AC46EC000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 25 17:09:38.326: //-1//AFW_:EE89AC46EC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 25 17:09:38.326: //-1//PACK:EE89AC46EC000:/tcl_ParamReadObjCmd:  operator
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists max-extension-length
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists max-extension-length
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 25 17:09:38.326: //-1//TCL :EE89AC46EC000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 25 17:09:38.326: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 25 17:09:38.326: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 25 17:09:38.326: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 25 17:09:38.326: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 25 17:09:38.326: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 25 17:09:38.326: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 25 17:09:38.326: FSM start state CALL_INIT(1)
Jul 25 17:09:38.326: //-1//AFW_:EE89AC46EC000:/Tcl_Link: Script autoattend succesfully linked.
Jul 25 17:09:38.330: //1303//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 25 17:09:38.330: //1303//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 25 17:09:38.330: //1303//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 25 17:09:38.330: //1303//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 25 17:09:38.330: //1303//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 25 17:09:38.330: //1303//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 25 17:09:38.330: //1303//AFW_:/vtr_lg_dnis: argc 2 argindex 2
DNIS sip:750@fa0/4_public_ip_of cube::5060
Jul 25 17:09:38.334: //1303//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 25 17:09:38.334: //1303//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 25 17:09:38.334: //1303//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 25 17:09:38.334: //1303//TCL :/tcl_PutsObjCmd: act_Setup
Jul 25 17:09:38.334: //1303//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 25 17:09:38.334: //1303//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 25 17:09:38.334: //1303//AFW_:/vtd_lg_incoming: argc 2
Jul 25 17:09:38.334: //1303//AFW_:/vtd_lg_incoming: Legs [1303 ]
Jul 25 17:09:38.334: //1303//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 17:09:38.334: //1303//TCL :/tcl_LegObjCmd:  leg setup sip:750@fa0/4_public_ip_of cube::5060 callInfo leg_incoming
Jul 25 17:09:38.334: //1303//AFW_:/vtd_lg_incoming: argc 4
Jul 25 17:09:38.334: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 25 17:09:38.338: //1303//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 25 17:09:38.338: //1303//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 25 17:09:38.358: //1303//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 25 17:09:38.358: //1303//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 25 17:09:38.358: //1303//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 25 17:09:38.358: //1303//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 25 17:09:38.358: //1303//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 25 17:09:38.358: //1303//AFW_:/vtd_lg_incoming: argc 2
Jul 25 17:09:38.358: //1303//AFW_:/vtd_lg_incoming: Legs [1303 ]
Jul 25 17:09:38.358: //1303//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 17:09:38.358: //1303//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 25 17:09:38.358: //1303//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 25 17:09:38.362: //1303//AFW_:/vtd_lg_incoming: argc 2
Jul 25 17:09:38.362: //1303//AFW_:/vtd_lg_incoming: Legs [1303 ]
Jul 25 17:09:38.362: //1303//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 25 17:09:38.362: //1303//TCL :/tcl_PutsObjCmd:
Jul 25 17:09:38.362: //1303//TCL :/tcl_PutsObjCmd: End user busy or absent
proc act_Select
Jul 25 17:09:38.362: //1303//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1
Jul 25 17:09:38.362: //1303//AFW_:/vtd_lg_incoming: argc 3
Jul 25 17:09:38.362: //1303//TCL :/tcl_PutsObjCmd: Over ReTry
proc act_DestBusy
Jul 25 17:09:38.362: //1303//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 25 17:09:38.362: //1303//PACK:/tcl_MediaPlayObjCmd:  play
CUBE# leg_incoming _disconnect.au
Jul 25 17:09:38.362: //1303//PACK:/Media_Play_Start:
Jul 25 17:09:38.366: //1303//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 25 17:09:38.366: //1303//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
CUBE#debug voip dialpeer inout
voip dialpeer inout debugging is on
Jul 25 17:10:04.502: //-1/FB743A800000/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1
   Result=Partial Matches(1) after DP_MATCH_DEST
Jul 25 17:10:04.502: //-1/FB743A800000/DPM/dpMatchSafModulePlugin:
   dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Jul 25 17:10:04.502: //-1/FB743A800000/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Jul 25 17:10:04.814: //-1/FB743A800000/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=10
Jul 25 17:10:04.814: //-1/FB743A800000/DPM/dpMatchSafModulePlugin:
   dialstring=10, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Jul 25 17:10:04.814: //-1/FB743A800000/DPM/dpMatchPeersMoreArg:
Jul 25 17:10:05.218: //-1/FB743A800000/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=101, Peer Info Type=DIALPEER_INFO_SPEECH
CUBE#
   Match Rule=DP_MATCH_DEST; Called Number=101
Jul 25 17:10:05.218: //-1/FB743A800000/DPM/dpMatchSafModulePlugin:
   dialstring=101, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Jul 25 17:10:05.218: //-1/FB743A800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
CUBE#
Jul 25 17:10:15.946: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Jul 25 17:10:15.946: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jul 25 17:10:15.950: //-1/E8E0AA7B853E/DPM/dpAssociateIncomingPeerCore:
CUBE#Calling Number=, Called Number=, Voice-Interface=0x0,
Jul 25 17:10:15.950: //-1/E8E0AA7B853E/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 25 17:11:16.018: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:11:16.018: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 25 17:11:16.018: //-1/0CAEEE80853F/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:11:16.018: //-1/0CAEEE80853F/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 25 17:12:16.266: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:12:16.266: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 25 17:12:16.266: //-1/30980B8B8540/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:12:16.266: //-1/30980B8B8540/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 25 17:13:17.698: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:13:17.698: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 25 17:13:17.698: //-1/5535D1D78541/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:13:17.698: //-1/5535D1D78541/DPM/dpMatchSafModulePlugin:
Jul 25 17:14:19.414: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:14:19.414: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 25 17:14:19.414: //-1/79FE530C8542/DPM/dpAssociateIncomingPeerCore:
Jul 25 17:14:19.414: //-1/79FE530C8542/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 25 17:14:43.766: //1303//TCL :/tcl_CallObjCmd:  call close
Jul 25 17:14:43.766: //1303//TCL :/tcl_CallCloseObjCmd:  close
Thank you so much.
Hi Ahmed,
Beside config (As Mr Carlo mentioned), could you include network diagram too?
Hi Lan,
don't have the digram now but this client has simple design.
2 access switches ,1 distribution switch,business edition 3000 which has e1 and a sip trunk to the cisco unified border element.
Hi Ahmed.
Can you please share you entire config?
Carlo
Hi Carlo,here is the configuration :
CUBE#show run
Building configuration...
Current configuration : 9465 bytes
! Last configuration change at 21:08:55 SPB Thu Jul 25 2013 by admin
version 15.3
no service pad
service password-encryption
hostname CUBE
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
logging persistent filesize 100000
enable secret 4 UNqF18mxCS01YvOWxkp0dshs5kkLsiSJHfcktf9/Sqw
no aaa new-model
clock timezone SPB 4 0
ip dhcp excluded-address 10.41.201.245 10.41.201.254
ip dhcp pool VOICE
network 10.41.201.0 255.255.255.0
option 150 ip 10.41.201.250
default-router 10.41.201.252
dns-server 8.8.8.8 8.8.4.4
lease 3
no ip domain lookup
ip domain name sgsvostok.ru
ip inspect max-incomplete high 50000
ip inspect max-incomplete low 45000
ip inspect one-minute low 4500
ip inspect one-minute high 5000
ip inspect udp idle-time 25
ip inspect dns-timeout 7
ip inspect tcp idle-time 21600
ip inspect tcp finwait-time 7
ip inspect tcp synwait-time 15
ip inspect tcp block-non-session
ip inspect tcp max-incomplete host 150 block-time 3
ip inspect name IPFW tcp alert on audit-trail off router-traffic
ip inspect name IPFW udp alert on audit-trail off router-traffic
ip inspect name IPFW icmp router-traffic
ip inspect name IPFW http
ip inspect name IPFW ftp
ip inspect name IPFW ssh
ip inspect name IPFW dns
ip inspect name IPFW pop3
ip inspect name IPFW imap
ip inspect name IPFW telnet
ip inspect name IPFW microsoft-ds
ip inspect name IPFW netbios-dgm
ip inspect name IPFW netbios-ns
ip inspect name IPFW netbios-ssn
ip inspect name IPFW router
ip inspect name IPFW fragment maximum 10000 timeout 1
ip inspect name IPFW icabrowser
ip inspect name IPFW citrix
ip inspect name IPFW citriximaclient
ip inspect name IPFW ntp
ip inspect name IPFW pptp
ip inspect name IPFW https
ip inspect name IPFW dhcp-failover
ip inspect name IPFW smtp
ip inspect name IPFW sip
ip inspect name IPFW h323
ip cef
no ipv6 cef
ipv6 multicast rpf use-bgp
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  emptycapability
sip
  bind control source-interface FastEthernet4
  bind media source-interface FastEthernet4
  header-passing
  registrar server
  early-offer forced
  midcall-signaling passthru
voice class codec 1
application
service autoattend flash:/Customized-Script.tcl
  param aa-pilot 750
  param operator 100
global
crypto pki trustpoint TP-self-signed-884837505
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-884837505
revocation-check none
rsakeypair TP-self-signed-884837505
crypto pki certificate chain TP-self-signed-884837505
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  3......................................
        quit
license udi pid C881-CUBE-..................
username admin privilege 15 secret .......................
username vpnx password 7 ............................
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Loopback10
ip address 10.41.203.252 255.255.255.0
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
switchport access vlan 2
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
ip address 62.y.y.y 255.255.255.192
ip access-group INCOMING in
no ip unreachables
ip nat outside
ip inspect IPFW in
ip inspect IPFW out
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface Virtual-Template1
ip unnumbered Vlan2
ip nat inside
peer default ip address pool PPTP-Pool
no keepalive
ppp authentication ms-chap ms-chap-v2
interface Vlan1
ip address 10.41.5.18 255.255.255.0
interface Vlan2
ip address 10.41.201.252 255.255.255.0
ip nat inside
ip local pool PPTP-Pool 172.16.231.2 172.16.231.50
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface FastEthernet4 overload
ip nat inside source static tcp 10.41.201.250 443 62.y.y.y 443 extendable
ip nat inside source static tcp 10.41.201.250 443 62.y.y.y 10443 extendable
ip route 0.0.0.0 0.0.0.0 62.X.X.X
ip route 10.0.0.0 255.0.0.0 10.41.201.247
ip route 172.16.0.0 255.240.0.0 10.41.201.247
ip route 192.168.0.0 255.255.0.0 10.41.201.247
ip access-list extended INCOMING
permit icmp any any
permit tcp any any eq 22
permit tcp any any eq 1723
permit gre any any
deny   ip any any log
ip access-list extended NAT
permit ip 10.41.201.0 0.0.0.255 any
permit ip 172.16.231.0 0.0.0.255 any
logging trap debugging
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
incoming called-number .T
dial-peer voice 2 voip
destination-pattern [123456]..
voice-class codec 1
dial-peer voice 3 voip
description SIP CITY
destination-pattern 812.......
session target ipv4:62.X.X.X
codec g711ulaw
dial-peer voice 4 voip
description SIP CITY 7
destination-pattern .......
codec g711ulaw
dial-peer voice 5 voip
description LONG DISTANCE
destination-pattern ..........
codec g711ulaw
dial-peer voice 6 voip
description SIP Mobile
destination-pattern 9.........
codec g711ulaw
dial-peer voice 7 voip
description SIP INTERNATIONAL
destination-pattern 810T
codec g711ulaw
dial-peer voice 8 voip
description EMERGENCY
destination-pattern 0.
codec g711ulaw
dial-peer voice 9 voip
description TIME
destination-pattern 060
session target ipv4:62.X.X.X   (Sip provider)
codec g711ulaw
service autoattend
session target ipv4:10.41.201.250            ( ip address of bussiness edition 3000 )
codec g711ulaw
sip-ua
sip-server ipv4:62.X.X.X
line con 0
password 7
login
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 7
logging synchronous
login local
transport input telnet ssh
ntp master 3
end
I am sad to say that you have made totally wrong configuration.
Let check:
service autoattend
codec g711ulaw
I suppose AA TCL and audio file have been stored in CUBE right??
why your dial-peer point to another ip add other than CUBE??
Please "google" for guide to set up AA TCL
Hi Lan,you misread my main post ,first the inbound dial peer is the  important not the session target here. what i wrote in main post :
And to prove to you, here are all the kind of configurations:
Just notice also to hear the distorted sound and to  see that i am connected word on phone' s screen,i have to reaload the  script.Otherwise i see that the script is envolved but i see the wored  enter number like the phone is waiting more digits.
CUBE(config)#do dir flash:
Directory of flash:/
    1  -rw-    45064548   Mar 1 1984 04:01:00 +04:00  c880voice-universalk9_npe-mz.153-1.T.bin
    2  -rw-        3071  Apr 13 2013 00:47:54 +04:00  cpconfig-8xx.cfg
    3  -rw-         720  May 25 2013 22:00:58 +04:00  vlan.dat
    4  drw-           0  Apr 13 2013 00:48:10 +04:00  ccpexp
  240  -rw-        2464  Apr 13 2013 00:49:56 +04:00  home.shtml
  241  drw-           0  May 27 2013 10:09:14 +04:00  syslog
  246  -rw-       75650  Jul 25 2013 21:03:38 +04:00  en_dest_busy.au
  247  -rw-       37952  Jul 25 2013 21:03:54 +04:00  en_dest_unreachable.au
  248  -rw-       83291  Jul 25 2013 21:04:38 +04:00  en_disconnect.au
  249  -rw-       63055  Jul 25 2013 21:04:56 +04:00  en_enter_dest.au
  250  -rw-      496521  Jul 25 2013 21:05:42 +04:00  en_music_on_hold.au
  251  -rw-       63055  Jul 25 2013 21:06:24 +04:00  en_reenter_dest.au
  252  -rw-       71629  Jul 25 2013 21:06:56 +04:00  en_welcome.au
  253  -rw-        8073  Jul 25 2013 12:51:18 +04:00  its-CISCO.2.0.2.0.tcl
  254  -rw-        8185  Jul 25 2013 17:55:20 +04:00  its-CISCO.2.0.3.0.tcl
  255  -rw-        7996  Jul 25 2013 21:03:18 +04:00  Customized-Script.tc
USING LOOPBACK OF CUBE:  Hear nothing
application
  param aa-pilot 750
  param operator 100
global
service autoattend
session target ipv4:10.41.203.252           loopback address on cube
dtmf-relay h245-signal h245-alphanumeric
codec g711ulaw
CUBE(config)#do call application voice load autoattend
CUBE(config)#
Jul 27 10:02:01.940: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=8073, url=flash:/its-CISCO.2.0.2.0.tcl
Jul 27 10:02:01.940: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x8BD63470
Jul 27 10:02:01.940: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x8BD63470
Jul 27 10:02:01.940: //-1//AFW_:EE89AC4A8C000:/Tcl_Link: Linking script autoattend
Jul 27 10:02:01.944: //-1//TCL :EE89AC4A8C000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:02:01.944: //-1//TCL :EE89AC4A8C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:01.944: //-1//TCL :EE89AC4A8C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:01.944: //-1//AFW_:EE89AC4A8C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:02:01.944: //-1//TCL :EE89AC4A8C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:02:01.944: //-1//TCL :EE89AC4A8C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:02:01.948: //-1//AFW_:EE89AC4A8C000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:02:01.948: //-1//PACK:EE89AC4A8C000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:02:01.948: //-1//AFW_:EE89AC4A8C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:02:01.948: //-1//PACK:EE89AC4A8C000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:02:01.948: //-1//TCL :EE89AC4A8C000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:02:01.948: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:01.948: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:02:01.948: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:01.948: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:01.948: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:02:01.948: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:02:01.948: FSM start state CALL_INIT(1)
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
Jul 27 10:02:01.948: //-1//AFW_:EE89AC4A8C000:/Tcl_Link: Script autoattend succesfully linked.
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
Jul 27 10:02:14.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:02:14.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:02:14.408: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8124990466, Called Number=, Voice-Interface=0x0,
Jul 27 10:02:14.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:02:14.412: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.412: //-1/9B43DC800000/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8124990466, Called Number=750, Voice-Interface=0x0,
Jul 27 10:02:14.412: //-1/9B43DC800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.416: //-1//AFW_:EE89AC4B74000:/Tcl_Link: Linking script autoattend
Jul 27 10:02:14.420: //-1//TCL :EE89AC4B74000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:14.424: //-1//AFW_:EE89AC4B74000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:02:14.424: //-1//AFW_:EE89AC4B74000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:02:14.424: //-1//PACK:EE89AC4B74000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:02:14.424: //-1//PACK:EE89AC4B74000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:02:14.424: //-1//TCL :EE89AC4B74000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:02:14.428: //-1//TCL :EE89AC4B74000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:02:14.428: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.428: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:02:14.428: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.428: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.428: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:02:14.428: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:02:14.428: FSM start state CALL_INIT(1)
Jul 27 10:02:14.428: //-1//AFW_:EE89AC4B74000:/Tcl_Link: Script autoattend succesfully linked.
Jul 27 10:02:14.428: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:02:14.428: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.428: //3723//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 27 10:02:14.432: //3723//TCL :/tcl_PutsObjCmd:
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 27 10:02:14.432: //3723//AFW_:/vtr_lg_ani: argc 2 argindex 2
ANI sip:812XXXXXXX@10.41.201.250
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 27 10:02:14.432: //3723//AFW_:/vtr_lg_dnis: argc 2 argindex 2
DNIS sip:750@62.X.X.X:5060
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 27 10:02:14.432: //3723//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 27 10:02:14.432: //3723//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 27 10:02:14.432: //3723//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 27 10:02:14.432: //3723//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 27 10:02:14.432: //3723//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:02:14.432: //3723//AFW_:/vtd_lg_incoming: Legs [3723 ]
Jul 27 10:02:14.432: //3723//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:02:14.432: //3723//TCL :/tcl_LegObjCmd:  leg setup sip:750@62.X.X.X:5060 callInfo leg_incoming
Jul 27 10:02:14.432: //3723//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:02:14.432: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 27 10:02:14.432: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:02:14.436: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:02:14.436: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.436: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:02:14.436: //-1/9B43DC800000/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST_URI; URI=sip:750@62.X.X.X:5060
Jul 27 10:02:14.436: //-1/9B43DC800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.436: //-1/9B43DC800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:02:14.436: //3723//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 27 10:02:14.436: //3723//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 27 10:02:14.444: //-1/9B43DC800000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:02:14.444: //-1/9B43DC800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:14.448: //-1//AFW_:EE89AC4D44000:/Tcl_Link: Linking script autoattend
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:02:14.452: //-1//AFW_:EE89AC4D44000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:02:14.452: //-1//AFW_:EE89AC4D44000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:02:14.452: //-1//PACK:EE89AC4D44000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:02:14.452: //-1//TCL :EE89AC4D44000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:02:14.456: //-1//AFW_:EE89AC4D44000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:02:14.456: //-1//PACK:EE89AC4D44000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:02:14.456: //-1//TCL :EE89AC4D44000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:02:14.456: //-1//TCL :EE89AC4D44000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:02:14.456: //-1//TCL :EE89AC4D44000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:02:14.456: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.456: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:02:14.456: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.456: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:02:14.456: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:02:14.456: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:02:14.456: FSM start state CALL_INIT(1)
Jul 27 10:02:14.456: //-1//AFW_:EE89AC4D44000:/Tcl_Link: Script autoattend succesfully linked.
Jul 27 10:02:14.456: //3725//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 27 10:02:14.456: //3725//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 27 10:02:14.456: //3725//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 27 10:02:14.456: //3725//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 27 10:02:14.460: //3725//TCL :/tcl_PutsObjCmd:
ANI 8124990466
Jul 27 10:02:14.460: //3725//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 27 10:02:14.460: //3725//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 27 10:02:14.460: //3725//AFW_:/vtr_lg_dnis: argc 2 argindex 2
DNIS sip:750@62.X.X.X5060
Jul 27 10:02:14.460: //3725//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 27 10:02:14.460: //3725//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 27 10:02:14.460: //3725//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 27 10:02:14.460: //3725//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 27 10:02:14.460: //3725//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 27 10:02:14.460: //3725//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:02:14.460: //3725//AFW_:/vtd_lg_incoming: Legs [3725 ]
Jul 27 10:02:14.460: //3725//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:02:14.460: //3725//TCL :/tcl_LegObjCmd:  leg setup sip:750@62.X.X.X:5060 callInfo leg_incoming
Jul 27 10:02:14.460: //3725//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:02:14.460: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 27 10:02:14.460: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=750, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=750
   Result=Success(0) after DP_MATCH_DEST
Jul 27 10:02:14.460: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=750, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jul 27 10:02:14.460: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=750
Jul 27 10:02:14.464: //-1/9B43DC800000/DPM/dpMatchPeersCore:
Jul 27 10:02:14.464: //-1/9B43DC800000/DPM/dpMatchSafModulePlugin:
   dialstring=750, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Jul 27 10:02:14.464: //-1/9B43DC800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:02:14.464: //3725//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 27 10:02:14.464: //3725//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
Jul 27 10:02:14.472: //-1/9B43DC800000/DPM/dpAssociateIncomingPeerCore:
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=750
Jul 27 10:02:14.472: //-1/9B43DC800000/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
CUBE(config)#
Jul  27 10:02:14.472: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a  global identifier already present in the list of currently handled  calls. It is being refused.
CUBE(config)#
Jul 27 10:02:21.528: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:02:21.528: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:02:21.528: //-1/768EDCDD8EB7/DPM/dpAssociateIncomingPeerCore:
CUBE(config)#Calling Number=, Called Number=, Voice-Interface=0x0,
Jul 27 10:02:21.528: //-1/768EDCDD8EB7/DPM/dpMatchSafModulePlugin:
CUBE(config)#
Jul 27 10:02:29.472: //3725//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 27 10:02:29.472: //3725//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 27 10:02:29.472: //3725//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 27 10:02:29.472: //3725//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 27 10:02:29.472: //3725//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 27 10:02:29.472: //3725//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:02:29.472: //3725//AFW_:/vtd_lg_incoming: Legs [3725 ]
Jul 27 10:02:29.472: //3725//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:02:29.472: //3725//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 27 10:02:29.472: //3725//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 27 10:02:29.472: //3725//TCL :/tcl_PutsObjCmd:
proc act_Select
Jul 27 10:02:29.472: //3725//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1 pattern
Jul 27 10:02:29.472: //3725//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:02:29.476: //3725//TCL :/tcl_PutsObjCmd:
proc act_DestBusy
Jul 27 10:02:29.476: //3725//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 27 10:02:29.476: //3725//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 27 10:02:29.476: //3725//AFW_:/vtd_lg_incoming: argc 3
Jul 27 10:02:29.476: //3725//AFW_:/vtd_lg_incoming: Legs [3725 ]
Jul 27 10:02:29.476: //3725//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
CUBE(config)#
Jul 27 10:02:29.476: //3725//PACK:/Media_Play_Start:
Jul 27 10:02:29.476: //3725//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 27 10:02:29.476: //3725//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
CUBE(config)#
Jul 27 10:02:34.988: //3723//TCL :/tcl_CallObjCmd:  call close
Jul 27 10:02:34.988: //3723//TCL :/tcl_CallCloseObjCmd:  close
Jul 27 10:02:34.996: //3725//TCL :/tcl_CallObjCmd:  call close
Jul 27 10:02:34.996: //3725//TCL :/tcl_CallCloseObjCmd:  close
application
service autoattend flash:/its-CISCO.2.0.2.0.tcl
  paramspace english index 0
  paramspace english language en
  paramspace english location flash:/
  param aa-pilot 750
  paramspace english prefix en
  param operator 100
global
  service alternate default
dial-peer voice 750 voip
service autoattend
destination-pattern 750
session target ipv4:62.X.X.X     (FA0/4 Public ip address on cube :62.X.X.X)
incoming called-number 750
codec g711ulaw
Using The FA0/4 Public ip address on cube :62.X.X.X
CUBE#call application voice load autoattend
CUBE#
Jul 27 10:08:03.572: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=8073, url=flash:/its-CISCO.2.0.2.0.tcl
Jul 27 10:08:03.572: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x8BD62034
Jul 27 10:08:03.572: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x8BD62034
Jul 27 10:08:03.572: //-1//AFW_:EE89AC4E2C000:/Tcl_Link: Linking script autoattend
Jul 27 10:08:03.576: //-1//TCL :EE89AC4E2C000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:03.580: //-1//AFW_:EE89AC4E2C000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:08:03.580: //-1//AFW_:EE89AC4E2C000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:08:03.580: //-1//PACK:EE89AC4E2C000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:08:03.580: //-1//PACK:EE89AC4E2C000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:08:03.580: //-1//TCL :EE89AC4E2C000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:08:03.584: //-1//TCL :EE89AC4E2C000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:08:03.584: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:03.584: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:08:03.584: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:03.584: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:03.584: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:08:03.584: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:08:03.584: FSM start state CALL_INIT(1)
CUBE#
Jul 27 10:08:03.584: //-1//AFW_:EE89AC4E2C000:/Tcl_Link: Script autoattend succesfully linked.
CUBE#
CUBE#
CUBE#
Jul 27 10:08:16.424: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=750, Called Number=750, Peer Info Type=DIALPEER_INFO_SPEECH
Jul 27 10:08:16.424: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.424: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:08:16.428: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
Jul 27 10:08:16.428: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.428: //-1/7308AD800000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:16.428: //-1/7308AD800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.436: //-1//AFW_:EE89AC4F14000:/Tcl_Link: Linking script autoattend
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:16.440: //-1//AFW_:EE89AC4F14000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:08:16.440: //-1//AFW_:EE89AC4F14000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:08:16.440: //-1//PACK:EE89AC4F14000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:08:16.440: //-1//TCL :EE89AC4F14000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:08:16.444: //-1//TCL :EE89AC4F14000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:08:16.444: //-1//TCL :EE89AC4F14000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:08:16.444: //-1//AFW_:EE89AC4F14000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:08:16.444: //-1//PACK:EE89AC4F14000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:08:16.444: //-1//TCL :EE89AC4F14000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:08:16.444: //-1//TCL :EE89AC4F14000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:08:16.444: //-1//TCL :EE89AC4F14000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:08:16.444: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:16.444: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:08:16.444: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:16.444: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:16.444: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:08:16.444: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:08:16.444: FSM start state CALL_INIT(1)
Jul 27 10:08:16.444: //-1//AFW_:EE89AC4F14000:/Tcl_Link: Script autoattend succesfully linked.
Jul 27 10:08:16.444: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:16.448: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:16.448: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.448: //3736//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 27 10:08:16.448: //3736//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 27 10:08:16.448: //3736//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 27 10:08:16.448: //3736//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 27 10:08:16.448: //3736//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 27 10:08:16.448: //3736//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 27 10:08:16.448: //3736//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 27 10:08:16.448: //3736//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:08:16.448: //3736//AFW_:/vtd_lg_incoming: Legs [3736 ]
Jul 27 10:08:16.448: //3736//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:08:16.448: //3736//TCL :/tcl_LegObjCmd:  leg setup sip:750@62.X.X.X:5060 callInfo leg_incoming
Jul 27 10:08:16.448: //3736//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:08:16.452: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 27 10:08:16.452: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:08:16.452: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.452: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:08:16.452: //-1/7308AD800000/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST_URI; URI=sip:750@62.X.X.X5060
Jul 27 10:08:16.452: //-1/7308AD800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:16.452: //-1/7308AD800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:08:16.456: //3736//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 27 10:08:16.456: //3736//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
CUBE#
Jul 27 10:08:18.460: //-1/7308AD800000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:18.460: //-1/7308AD800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:18.464: //-1//AFW_:EE89AC4FFC000:/Tcl_Link: Linking script autoattend
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:08:18.468: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:08:18.468: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:08:18.468: //-1//PACK:EE89AC4FFC000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:08:18.468: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:08:18.472: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:08:18.472: //-1//TCL :EE89AC4FFC000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:08:18.472: //-1//TCL :EE89AC4FFC000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:08:18.472: //-1//AFW_:EE89AC4FFC000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:08:18.472: //-1//PACK:EE89AC4FFC000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:08:18.472: //-1//TCL :EE89AC4FFC000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:08:18.472: //-1//TCL :EE89AC4FFC000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:08:18.472: //-1//TCL :EE89AC4FFC000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:08:18.472: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:18.472: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:08:18.472: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:18.472: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:08:18.472: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:08:18.472: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:08:18.472: FSM start state CALL_INIT(1)
Jul 27 10:08:18.472: //-1//AFW_:EE89AC4FFC000:/Tcl_Link: Script autoattend succesfully linked.
Jul 27 10:08:18.472: //3738//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 27 10:08:18.476:
Jul 27 10:08:18.476: //3738//TCL :/tcl_PutsObjCmd:
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 27 10:08:18.476: //3738//AFW_:/vtr_lg_ani: argc 2 argindex 2
ANI 8124990466
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 27 10:08:18.476: //3738//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 27 10:08:18.476: //3738//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 27 10:08:18.476: //3738//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 27 10:08:18.476: //3738//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 27 10:08:18.476: //3738//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 27 10:08:18.476: //3738//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:08:18.476: //3738//AFW_:/vtd_lg_incoming: Legs [3738 ]
Jul 27 10:08:18.476: //3738//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:08:18.476: //3738//TCL :/tcl_LegObjCmd:  leg setup sip:750@62.X.X.X:5060 callInfo leg_incoming
Jul 27 10:08:18.476: //3738//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:08:18.476: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 27 10:08:18.476: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:08:18.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:08:18.480: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:18.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:08:18.480: //-1/7308AD800000/DPM/dpMatchPeersCore:
Jul 27 10:08:18.480: //-1/7308AD800000/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:18.480: //-1/7308AD800000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:08:18.480: //3738//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 27 10:08:18.480: //3738//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
CUBE#
Jul 27 10:08:20.488: //-1/7308AD800000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:20.488: //-1/7308AD800000/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 27 10:08:20.488: %CALL_CONTROL-6-CALL_LOOP: The  incoming call has a global identifier already present in the list of  currently handled calls. It is being refused.
CUBE#
Jul 27 10:08:27.440: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:27.440: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:08:27.440: //-1/50A899738EC4/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:08:27.440: //-1/50A899738EC4/DPM/dpMatchSafModulePlugin:
CUBE#
Jul 27 10:08:35.488: //3738//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 27 10:08:35.488: //3738//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 27 10:08:35.488: //3738//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 27 10:08:35.488: //3738//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 27 10:08:35.488: //3738//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 27 10:08:35.488: //3738//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:08:35.488: //3738//AFW_:/vtd_lg_incoming: Legs [3738 ]
Jul 27 10:08:35.488: //3738//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:08:35.488: //3738//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 27 10:08:35.488: //3738//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 27 10:08:35.488: //3738//TCL :/tcl_PutsObjCmd:
proc act_Select
Jul 27 10:08:35.488: //3738//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1 pattern
Jul 27 10:08:35.488: //3738//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:08:35.492: //3738//TCL :/tcl_PutsObjCmd:
proc act_DestBusy
Jul 27 10:08:35.492: //3738//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 27 10:08:35.492: //3738//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 27 10:08:35.492: //3738//AFW_:/vtd_lg_incoming: argc 3
Jul 27 10:08:35.492: //3738//AFW_:/vtd_lg_incoming: Legs [3738 ]
Jul 27 10:08:35.492: //3738//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
CUBE#
Jul 27 10:08:35.492: //3738//PACK:/Media_Play_Start:
Jul 27 10:08:35.492: //3738//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 27 10:08:35.492: //3738//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
CUBE#
Jul 27 10:08:52.608: //3736//TCL :/tcl_CallObjCmd:  call close
Jul 27 10:08:52.608: //3736//TCL :/tcl_CallCloseObjCmd:  close
Jul 27 10:08:52.616: //3738//TCL :/tcl_CallObjCmd:  call close
Jul 27 10:08:52.616: //3738//TCL :/tcl_CallCloseObjCmd:  close
Using the same dial-peer but as sip dialpeer instead of h322 ( hear distorted sound again )
application
  param aa-pilot 750
  param operator 100
global
service autoattend
session protocol sipv2
dtmf-relay sip-kpml sip-notify h245-signal h245-alphanumeric
codec g711ulaw
CUBE(config)#
Jul 27 10:23:42.304: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:23:42.304: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:23:42.304: //-1/71F5C2478ED3/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:23:42.308: //-1/71F5C2478ED3/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:23:42.308: //-1/71F5C2478ED3/DPM/dpMatchSafModulePlugin:
CUBE(config)#
Jul 27 10:24:04.904: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=8073, url=flash:/its-CISCO.2.0.2.0.tcl
Jul 27 10:24:04.904: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x8BD63D1C
Jul 27 10:24:04.904: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x8BD63D1C
Jul 27 10:24:04.904: //-1//AFW_:EE89AC50E4000:/Tcl_Link: Linking script autoattend
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:24:04.912: //-1//AFW_:EE89AC50E4000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:24:04.912: //-1//AFW_:EE89AC50E4000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:24:04.912: //-1//PACK:EE89AC50E4000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:24:04.912: //-1//TCL :EE89AC50E4000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:24:04.912: //-1//PACK:EE89AC50E4000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:24:04.916: //-1//TCL :EE89AC50E4000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:24:04.916: //-1//TCL :EE89AC50E4000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:24:04.916: //-1//TCL :EE89AC50E4000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:24:04.916: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:04.916: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:24:04.916: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:04.916: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:04.916: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:24:04.916: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:24:04.916: FSM start state CALL_INIT(1)
CUBE(config)#
CUBE(config)#
CUBE(config)#
CUBE(config)#
Jul 27 10:24:04.916: //-1//AFW_:EE89AC50E4000:/Tcl_Link: Script autoattend succesfully linked.
CUBE(config)#
CUBE(config)#
CUBE(config)#
Jul 27 10:24:13.500: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:24:13.500: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.500: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:24:13.500: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:13.504: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:13.504: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.504: //-1/AD734A000000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:13.504: //-1/AD734A000000/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.508: //-1//AFW_:EE89AC4604000:/Tcl_Link: Linking script autoattend
Jul 27 10:24:13.512: //-1//TCL :EE89AC4604000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists aa-pilot
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists aa-pilot
Jul 27 10:24:13.516: //-1//AFW_:EE89AC4604000:/vtr_cf_avpair_exists: argc 3 argindex 2
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagObjCmd:  infotag get cfg_avpair aa-pilot
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair aa-pilot
Jul 27 10:24:13.516: //-1//AFW_:EE89AC4604000:/vtr_cf_avpair: argc 3 argindex 2
Jul 27 10:24:13.516: //-1//PACK:EE89AC4604000:/tcl_ParamReadObjCmd:  aa-pilot
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists operator
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists operator
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagObjCmd:  infotag get cfg_avpair operator
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair operator
Jul 27 10:24:13.516: //-1//PACK:EE89AC4604000:/tcl_ParamReadObjCmd:  operator
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_FSMObjCmd:  fsm define fsm CALL_INIT
Jul 27 10:24:13.516: //-1//TCL :EE89AC4604000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
Jul 27 10:24:13.520: //-1//TCL :EE89AC4604000:/tcl_FSMDefineObjCmd: FSM Data structure
Jul 27 10:24:13.520: (CALLDISCONNECT(2), ev_media_done(186)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:13.520: (GETDEST(3), ev_collectdigits_done(247)--(act_GotDest)-->(HANDOFF(4))
Jul 27 10:24:13.520: (any_state(0), ev_disconnect_done(21)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:13.520: (any_state(0), ev_disconnected(20)--(act_Cleanup)-->(any_state(0))
Jul 27 10:24:13.520: (HANDOFF(4), ev_setup_done(238)--(act_CallSetupDone)-->(CONTINUE(5))
Jul 27 10:24:13.520: (CALL_INIT(1), ev_setup_indication(35)--(act_Setup)-->(GETDEST(3))
Jul 27 10:24:13.520: FSM start state CALL_INIT(1)
Jul 27 10:24:13.520: //-1//AFW_:EE89AC4604000:/Tcl_Link: Script autoattend succesfully linked.
Jul 27 10:24:13.520: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:13.520: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.520: //3759//TCL :/tcl_PutsObjCmd: proc act_Setup
Jul 27 10:24:13.520: //3759//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
Jul 27 10:24:13.524: //3759//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Jul 27 10:24:13.524: //3759//AFW_:/vtr_lg_ani: argc 2 argindex 2
Jul 27 10:24:13.524: //3759//TCL :/tcl_PutsObjCmd:
Jul 27 10:24:13.524: //3759//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
Jul 27 10:24:13.524: //3759//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Jul 27 10:24:13.524: //3759//AFW_:/vtr_lg_dnis: argc 2 argindex 2
DNIS sip:750@62.X.X.X :5060
Jul 27 10:24:13.524: //3759//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
Jul 27 10:24:13.524: //3759//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Jul 27 10:24:13.524: //3759//AFW_:/vtw_ms_language: argc 3 argindex 2
Jul 27 10:24:13.524: //3759//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
Jul 27 10:24:13.524: //3759//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Jul 27 10:24:13.524: //3759//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:24:13.524: //3759//AFW_:/vtd_lg_incoming: Legs [3759 ]
Jul 27 10:24:13.524: //3759//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:24:13.524: //3759//TCL :/tcl_LegObjCmd:  leg setup sip:750@62.X.X.X :5060 callInfo leg_incoming
Jul 27 10:24:13.524: //3759//AFW_:/vtd_lg_incoming: argc 4
Jul 27 10:24:13.524: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
Jul 27 10:24:13.524: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:24:13.524: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.524: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:24:13.528: //-1/AD734A000000/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST_URI; URI=sip:750@62.X.X.X :5060
Jul 27 10:24:13.528: //-1/AD734A000000/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:13.528: //-1/AD734A000000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:24:13.528: //3759//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
Jul 27 10:24:13.528: //3759//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
CUBE(config)#
  Jul 27 10:24:14.040: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul 27 10:24:14.040: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul 27 10:24:14.040: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jul 27 10:24:14.040: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:14.044: //-1/AD734A000000/DPM/dpAssociateIncomingPeerCore:
Jul 27 10:24:14.044: //-1/AD734A000000/DPM/dpMatchSafModulePlugin:
Jul  27 10:24:14.048: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a  global identifier already present in the list of currently handled  calls. It is being refused.
Jul 27 10:24:14.052: //3759//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
Jul 27 10:24:14.052: //3759//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
Jul 27 10:24:14.052: //3759//AFW_:/vtr_ev_status: argc 2 argindex 2
Jul 27 10:24:14.052: //3759//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
Jul 27 10:24:14.052: //3759//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
Jul 27 10:24:14.052: //3759//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:24:14.056: //3759//AFW_:/vtd_lg_incoming: Legs [3759 ]
Jul 27 10:24:14.056: //3759//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Jul 27 10:24:14.056: //3759//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
Jul 27 10:24:14.056: //3759//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
Jul 27 10:24:14.056: //3759//AFW_:/vtd_lg_incoming: argc 2
Jul 27 10:24:14.056: //3759//TCL :/tcl_PutsObjCmd:
Call failed. Play prompt and collect digit
proc act_Select
Jul 27 10:24:14.056: //3759//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1 pattern
Jul 27 10:24:14.056: //3759//AFW_:/vtd_lg_incoming: argc 4
proc act_DestBusy
Jul 27 10:24:14.056: //3759//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
Jul 27 10:24:14.056: //3759//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
Jul 27 10:24:14.056: //3759//AFW_:/vtd_lg_incoming: argc 3
Jul 27 10:24:14.056: //3759//PACK:/Media_Play_Start:
Jul 27 10:24:14.060: //3759//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
Jul 27 10:24:14.060: //3759//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
Jul 27 10:24:14.060: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
CUBE(config)#
Jul 27 10:24:14.060: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
CUBE(config)#
Jul 27 10:24:33.172: //3759//TCL :/tcl_CallObjCmd:  call close
Jul 27 10:24:33.172: //3759//TCL :/tcl_CallCloseObjCmd:  close
Re: TCL Auto Attendant Problem
Hi Ahmed,
I really try to support but your existing configuration dial-plan has issue, let notice the output of your debug:
"Call failed. Play prompt and collect digit"
The AA was invoked did not mean the configuration is OK, the incorrect dialing plan resulted in mis-function of AA.
Hi Lan,first thank you so much for your support and time,second in my understanding and searches
this message should be seen when you are using the same source and session target but this message shouldn't be seen if you add the incoming called number ,which i already have.I ll keep troubleshooting and update the post as soon as i find something.
Thanks man.
Hi Admed,
Below is the topology I used to use to setup AA, (I apply it to your scenario):
(I did not see any E1 trunking in your configuration of CUBE)
BE 3000 ---------(LAN-Ethernet)---------- (CUBE) --------Sip Trunking to outside
For test, let use H323 between BE 3000 and CUBE instead of sip .
dont forget to bind H323 with interfaces of BE3000 and CUBE, ex:
"h323-gateway voip interface
h323-gateway voip bind srcaddr"
on BE 3000 side, make the dial-peer  point to CUBE AA, on CUBE side make dial-peer:
description AA service
service autoattend
session target ipv4:(ipv4 of CUBE itself that you associated with H323)
codec g711ulaw
dtmf-relay h245-alphanumeric h245-signal
no vad
(Dont forget to enable H323 on BE3000 interface that you use to connect to AA voip)
On CUBE, (optionally) you also can use "ip address trusted list" to allow voip communication from BE3000 under "voice service voip"
I usually make equipvalent setting as above and did not encounter any issue with AA
1015
