01-30-2012 06:46 AM - edited 03-16-2019 09:17 AM
Am using cisco 2911 router - C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4,
Below config works fine, but i can reach only operator & i can dial by extension.
i cannot create param aa-hunt1 for dialing individual digits. How to achive that eg press 1 for sales and 2 for marketing.
I also tried with cme-b-acd-2.1.2.3 & 3.0.0.2. I cannot reach the aa prompt in this tcl application.
application
service nicknetaa flash://its-CISCO.2.0.3.0.tcl
param operator 4001
paramspace english language en
paramspace english index 0
paramspace english location flash://
paramspace english prefix en
param aa-pilot 4999
dial-peer voice 4999 voip
service nicknetaa
destination-pattern 4999
session target ipv4:172.16.28.1
incoming called-number 4999
dtmf-relay h245-alphanumeric
codec g711ulawru
no vad
Any suggestion...
Thanks...
01-30-2012 07:26 AM
Have you read this:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html
You need to configure queue service applications for those as outlined in the doc.
HTH,
Chris
01-30-2012 07:36 AM
Hi Chris,
I cannot access the document...
I also tried the below config but the call is not hitting the aa pilot 8805(audio files are not played)
all audio files & tcl files are placed in flash...
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
paramspace english index 1
param operator 1405
param aa-pilot 4999
param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
param aa-hunt1 1771
01-30-2012 07:38 AM
Sorry, here is the non-partner link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html
Chris
01-31-2012 01:02 AM
Hi Chris,
Can access the document and configured from the scratch but still facing the same problem.
Call hits the FXO port and unable to access the aa-pilot (doesn't connect or no voice prompt).
When i use its-cisco-2.0.3.0.tcl it works fine but only two option (dial by extn & operator).
Any specific TCL version to be used for 2911?
Just need to dial as follows : press 1 for sales press 2 for marketing.
Can we use TCL AA in 2911 without CME?
Raffi...
01-31-2012 03:43 AM
Hi Chris,
Can access the document and configured from the scratch but still facing the same problem with cme-b-acd-2.1.2.3 & 3.0.0.2. Call hits the FXO port and unable to access the aa-pilot (doesn't connect or no voice prompt).
1.) When i use its-cisco-2.0.3.0.tcl it works fine but only two option (dial by extn & operator).
2.) Sometimes when an external line attempts to connect through the system, but the external POTS phone disconnects before the IP phone user picks up - the IP phone will ring FOREVER - until the IP phone is taken off-hook.
Like in this example... A user in POTS calls the business number after hours. Nobody inside the network picks up the phone. But it continues to ring, continually - until users come to work in the morning and off-hook their phones.
Is there any way to limit the number of rings on inbound phone calls from POTS, prior to simply disconnecting them?
Any specific TCL version to be used for 2911 ?
Thanks & Regards,
Raffi
01-31-2012 04:33 AM
Regarding disconnect issue:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
And many discussion here on forum.
If you know what you're doing, you can use TCL AA without CME.
