TCL IVR AA Script
I am looking for a TCL IVR script that says something along the lines of press 1 for person a. Press 2 for person b etc. Also does anyone have any good script editors specifically for TCL IVR scripts that they would recommend.
  • IP Telephony
Hall of Fame Super Gold
Re: TCL IVR AA Script
That is B-ACD/AA for up to 9 choices.
For easy programming of IVR features, look at CUE that has a GUI editor, TCL/IVR doesn't have one and I think it will never have.
Unfortunately we can't use CUE in this situation. It looks like I actually need the SRST version of the AA script in the situation in question after more research but I can't find the file. The Cisco Press Voice Gateways and Gatekeepers book indicates SRST-2.0.zip contains the SRST AA tcl script and is compatible with SRST version 3.0 or 3.3 and that the latest versions don't contain the SRST AA script. I can't find the SRST-2.0.zip file. Does anyone know where I can find the file?
I was not aware of an AA TCL/IVR version specific for use with SRST.
I supposed you can use either the standard B-ACD/AA on CCO under CME area, or the improved "PL2" branch that I maintain at:
http://pbevila.fastmail.fm/public/app-b-acd-aa-2.1.2.2-pl2.tcl
244
