You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
TCL IVR with SIP trunk on Cisco router
Hi All,
I am using a cisco 2900 series router for SIP trunk.  I configured a TCL script for IVR but when incoming received  from outside no prompts play just silence when i give any extension like 299 it transfer the calls to extension but i can't why it is not playing welcome prompts. Below is my config kindly help  me:
Router#dir flash:
Directory of flash0:/
    1  -rw-    99077424  Nov 26 2013 13:16:26 +00:00  c2900-universalk9-mz.SPA.152-4.M4.bin
    2  -rw-        3064  Nov 26 2013 13:26:08 +00:00  cpconfig-29xx.cfg
    3  -rw-          19   Jul 9 2014 07:02:46 +00:00  CP3905.9-4-1-0.loads
    4  drw-           0  Nov 26 2013 13:26:34 +00:00  ccpexp
  240  -rw-        2464  Nov 26 2013 13:28:18 +00:00  home.shtml
  241  -rw-     2820567   Jul 9 2014 07:03:20 +00:00  APP3905.9-4-1-0.zz
  242  drw-           0   Jul 9 2014 07:06:42 +00:00  its
  247  -rw-         660  Jul 16 2014 08:21:00 +00:00  vlan.dat
  249  -rw-       42484  Jul 18 2014 09:09:42 +00:00  en_dest_busy.au
  250  -rw-       26376  Jul 18 2014 09:09:42 +00:00  en_dest_unreachable.au
  248  -rw-       14352  Jul 18 2014 09:09:42 +00:00  en_disconnect.au
  244  -rw-       27192  Jul 18 2014 09:09:42 +00:00  en_enter_dest.au
  243  -rw-       17159  Jul 18 2014 09:09:44 +00:00  en_reenter_dest.au
  246  -rw-       14862  Jul 18 2014 09:09:44 +00:00  en_welcome.au
  245  -rw-        8293  Jul 18 2014 09:09:44 +00:00  its-CISCO.2.0.3.0.tcl
256487424 bytes total (152227840 bytes free)
Sh run:
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 redirect ip2ip
 fax protocol pass-through g711alaw
 sip
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g729r8
voice translation-rule 1
 rule 1 /.+/ /199/
voice translation-rule 2
 rule 1 /^/ /9/
voice translation-profile inc
 translate called 1
voice translation-profile out
 translate called 2
application
 service cmeaa flash:its-CISCO.2.0.3.0.tcl
  param aa-pilot 199
  paramspace english language en
  paramspace english index 1
  param operator 0
  paramspace english location flash:
  paramspace english prefix en
dial-peer voice 2 voip
 service cmeaa
 destination-pattern 199
 session protocol sipv2
 session target ipv4:192.168.2.254
 incoming called-number 199
 dtmf-relay rtp-nte
 codec g711alaw
dial-peer voice 9 voip
 description **** INCOMING ****
 translation-profile incoming inc
 session target sip-server
 incoming called-number xxxxxxxxxxx
 dtmf-relay rtp-nte
 codec g711alaw
  • IP Telephony
1 REPLY
And one more thing after
And one more thing after activating debug i get following error:
Jul 18 12:27:00.698: //2269//PACK:/Media_Play_Start:
*Jul 18 12:27:00.698: //2269//TCL :/tcl_FSMObjCmd:  fsm setstate GETDEST
*Jul 18 12:27:00.698: //2269//TCL :/tcl_FSMSetStateObjCmd: setstate setstate GETDEST
*Jul 18 12:27:00.698: //2269//MSM :/ms_asDone_buginf: Stream Association Failed: Requested codec=0x5=g711ulaw, Negotiated codec=0x6=g711alaw
*Jul 18 12:27:00.698: //2269//AFW_:/AFW_FSM_Drive: FSM no match for (GETDEST[3],ev_media_done[185])
Regard,
Haseeb Ahmad
190
