Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
TCL media record maxMemory size ?
I am writing a tcl script that records to flash.
And I have a problem with the parameter maxMemory, if I set it above 256000 it seems to be lowered to 256000 when the script is initiated on the router.
Here is my recordInfo section
set recordInfo(codec) g711ulaw
set recordInfo(finalSilence) 0
set recordInfo(dtmfTerm) enable
set recordInfo(maxMemory) 512000
set recordInfo(fileFormat) wav
set recordInfo(beep) beep
set url flash:holiday.wav
If anyone has any idea :)
regards
Gudmundur
Silver
Re: TCL media record maxMemory size ?
it only records a file that is 256000 in size
You can use commands in global config mode:
ivr record memory session kilobytes
ivr record memory system kilobytes
to increase maximum recording size.
Additional information you can find here: http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_i1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1021609
346
