TCL on VG-202/204
William Bell
All,
I think I know the anser to this question, but I don't have access to a VG-202 or VG-204 to confirm. I have a need to run a TCL app on a VG-202 or -204. I know the app will run on a VG-224. I read a datasheet which says something along the lines that a VG-202/-204 uses the same IOS features as a VG-224. However, in Feature Navigator TCL features are not listed for the VG-202/-204 flavors of IOS (whereas they are listed in the VG-224 flavor).
I always thought that the VG-202/-204 used a scalled down version of IOS and the Feature Navigator seems to support this assumption. So, I have to conclude that TCL is *not* supported on VG-202/-204.
Can anyone confirm or deny?
Just for context, the TCL script is for a voice application. To strip and parse some digits to select the appropriate analog port. I am a few steps removed from the script at the moment. So, this is more of a research thing.
Thanks in advance.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
paolo bevilacqua
TCL/IVR scripts loads, configure and run fine on the VG20x.
