Community Member
TCL script and early open voice channel (before connect)
I need to play media before connect. I use SIP for incoming call - media must play to incoming sip call.
But when I use such script construction - no any rtp information in 183 progress message, but rtp is playng.
So if no any information in 183 - calling parity didn't hear anything and only silence
    leg setupack leg_incoming
    leg proceeding leg_incoming
    leg progress leg_incoming
    if {[infotag get cfg_avpair_exists PlayMedia]} {
        set PlayMedia [infotag get cfg_avpair PlayMedia]
        puts "\n == PlayMedia found! $PlayMedia =="        } else {                                                         set PlayMedia "flash:/Prompts/greeting_rec.au"
        puts "\n == No PlayMedia found! Try to use default! $PlayMedia =="        }                                                media play leg_incoming $PlayMedia
dial-peer voice 1103 voip
translation-profile incoming call_in
incoming called-number 495xxxxxxx$
voice-class sip rel1xx supported "100rel"
voice-class sip early-offer forced
voice-class sip send 180 sdp
dtmf-relay rtp-nte h245-alphanumeric
codec g711ulaw
fax protocol pass-through g711ulaw
ip qos dscp cs5 media
no vad
Nov  3 15:45:41.809: //59465/D42C3EE59EAE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 10.10.10.2:5060;branch=z9hG4bKa7bb28b5bb7a65ad42f4bbb6d
To: <sip:495xxxxxxx@10.220.17.12;user=phone>;tag=2B3149F8-1ACE
Date: Sun, 03 Nov 2013 15:45:41 GMT
Call-ID: SBCcb069742cdd861e51fdc44384cccf0af@10.10.01.5
CSeq: 1 INVITE
Require: 100rel
RSeq: 2821
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Contact: <sip:495xxxxxxx@10.10.10.5:5060>
Server: Cisco-SIPGateway/IOS-15.2.4.M5
Content-Length: 0
1 REPLY
Hall of Fame Super Gold
Wrong forum, try developer.cisco.com, GWAPI forum.
185
