07-11-2012 02:06 PM - edited 03-16-2019 12:09 PM
Hi All,
I need to configure AA its-CISCO.2.0.3.0.tcl script for incoming calls from SIP trunk, but what I know is its-CISCO.2.0.3.0.tcl only work with incoming dial-peer not outgoing dial-peer and my SIP provider uses G.711alaw and the script working only with ulaw.
Is there any solution other than CUE, UCX , CUCCX.
Thanks in advance.
07-11-2012 03:46 PM
TCL/IVR scripts can play G.711a prompts with no problem.
07-11-2012 04:34 PM
Is this in the new versions??
I think I read before that it must be used with 711ulaw only.
I found this in the readme file:
its_Cisco.2.0.1.0.tcl has added call handoff capability for transfering or/and forwarding
an incoming call received from this script to CME 3.0 code with built-in H.450 support.
But in my case I have SIP not H.323, so is there any solution?
07-12-2012 01:41 AM
Any version of script can work.
TCL scripts can work with any signalling protocol. Cisco sometime makes a confusing use of terms.
Thanks for the nice rating and good luck!
07-12-2012 02:25 AM
Dont forget that most prompts are recorded in g711ulaw. So if you want to use g711alaw, your prompts needs to be in that format otherwise it may not work
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-12-2012 05:14 AM
thank you too much and +5 for both.
sometimes we forget the meaning of codecs. I will use g711alaw files and test
07-24-2015 10:14 AM
Hi JustForVoice,
Did you manage to run this script over SIP dial-peer as i am facing issue while using
" its-CISCO.2.0.2.0.tcl" script . It triggers the application but didn't find "dest" number for AA-pilot number although i have configured that number as well.
