07-25-2012 08:30 AM - edited 03-16-2019 12:22 PM
I have two cases to manipulate digits on a dial-peer on a IOS cube:
1)
eq. 35400 -> 5400
this case is simple, I can use translation rules on the dial-peer.
2)
eq. 48600 -> 5400
I have a lot of numbers to translate in an other number don't followed any rules. Here I can't use the voice translation rules to do this. Now, I want to create a TCL script to translate this called numbers.
draft config:
voice translation-rule 1
rule 1 /^.\(....\)$/ /\1/
voice translation-profile 5to4digits
translate called 1
dial-peer voice 100 voip
description *** INCOMING from Avaya side dial-peer ***
translation-profile outgoing 5to4digits
incoming called-number .
session protocol sipv2
destination-pattern [3-4]....
voice-class sip bind control source <IP Add. Avaya>
voice-class sip bind media source <IP Add. Avaya>
service digit_manipulation
dial-peer voice 3001 voip
description *** OUTGOING to CUCM ***
destination-pattern ....
session target ipv4:<CUCM>
voice-class codec 1
dtmf-relay rtp-nte
no vad
*do you have a tcl example scrip with similar digit manipulation?
*what is first executed, the translation rule or the tcl script?
*can I bind the dial-peer on the source ip adress of the avaya pbx, I just want to manipulate digit if it is coming from avaya and I have other dial peers matching to the 5-digits?
Thanks a lot for all the hints!
Best regards,
Christian
07-25-2012 08:51 AM
Writing TCL(IVR scripts is not so easy, you can judge by yourself:
http://www.cisco.com/en/US/docs/ios/voice/tcl/developer/guide/tclivrv2.html
You can send further questions on the matter to developer.cisco.com, TCL/IVR forum.
07-25-2012 11:02 AM
Can't you just do is in cucm?
Put a special CSS on the trunk that handles the incoming calls from the cube and put in all translations you need.
Erik
