Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
TCL Scripting help needed
Hi guys, okay, so this isn't telephony related but judging from the search I just did, there are more people in the VoIP groups with tcl scripting experience than in the wan/lan group where this probably belongs.
So what I'm trying to do is have my router use Tcl to pull down a webpage from a cable modem.
Here's my code so far.
set sock [socket 192.168.100.1 80]
puts $sock "GET /signaldata.htm HTTP/1.0\n\n"
flush $sock
set result [ gets $sock ]
puts stdout "OUTPUT:\n$result"
set exit_msg "closing socket"
close $sock
It doesn't work. All I get is:
OUTPUT:
I know the URL works because I can pull it up fine from my browser and a telnet to port 80 from the router itself also opens the socket for a brief moment.
Can anyone tell me what I'm doing wrong?
1 REPLY
Re: TCL Scripting help needed
Good idea to re-post this in Developers forum. You may get better response.
107
