TCP/UDP ports for IP Communicator and SecureCRT
Does anyone knows what are the TCP/UDP ports for IP Communicator and SecureCRT?
We need those to be configured into FW.
Many thanks in advance.
Maddox
Hall of Fame Super Silver
Re: TCP/UDP ports for IP Communicator and SecureCRT
IPCommunicator when used as SCCP endpoint uses TCP 2000, and UDP 16384-32767 for RTP stream.
sCRT uses port based on protocol that you are attmpting to connect with, so for telnet it uses TCP 23, SSH will use port 22.
HTH,
Chris
Chris,
Thank you for your help.
That latter UDP port is going to be the issue.
Is there a way to limit that down from 16k ports?
Maddox
605
