Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Teaming card for Network redundancy in CCM
is it possible to configure a teaming card in the CCM?
Or configure the two network ports so that there won'be a network failure for the CCM?
If the first network failed, then the communication will pass to the second network.
Re: Teaming card for Network redundancy in CCM
Yes,
You enable it using the server CLI using the "utils network failover enable" command.
what is the CCM version, is it windows based or applicance (=> ccm version 5)
For Windows version, you can team using the tools provided on the MCS platform, example, HP Teaming tool.
150
