Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
TEHO and Route Filters
I have a situation where I have configured TEHO or least cost routing for a customer who is running UCM 7.13.   They have 4 PRIs in different Local Calling Areas.  One is even in a different area code.   I setup route filters for each PRI that matched the area code and office code that is a local call to that PRI.
I then have 9.@ route patterns that have one of these route filters used.  I also have a 9.@ pattern with a long distance route filter defined as long distance direct dial exists, and area code exists.
The problem I am having is that some of the calls for the office codes that I have defined in the TEHO route filters are being ignored and routed as LD calls.
What I have determined is that when I create an office code pattern in a route filter clause as 32[0125789], not all the numbers in the [ ] will match.
If the office code to be matched is 328, it is ignored, and sent as a LD call. But 325 would match, and the call is routed out a local gateway.
I split that office code string into 2 clauses and the calls are routed normally.  I split 32[0125789] into 32[0125] and 32[789].
The issue is that there are alot of other clauses like this one and will necessitate more route filters being created.
Has anyone else run into this issue?   Is this a bug or a known limitation.   I have not found anything under the route filter configuration guides about this.
Thanks.
1 REPLY
Hall of Fame Super Silver
Re: TEHO and Route Filters
Without having the entire picutre of your configuration, i.e. CSS/PT conifg, Route Patterns it is difficult to tell if there is somthing else going on, but from what you are describing it sounds like a bug. What is Dialed Number Analyzer showing for this call?
Chris
210
