TEHO on 7.X
I am trying to implement TEHO for a newly added location. The scenario and configuration is as follows
I am calling an international number  from location 1 in device pool A
Trying to TEHO it to location 2  in device pool B
The translation pattern points to a route list with location B's gateway and standard local route group.
Whenever I make a call the call is going out of location A's gateway. If i remove standard local route troup from the pattern of the international number I am trying to call to I get a fast busy tone. I confirmed that the call does not reach the gateway onlywhen i do a debug isdn q931. It is failing in CCM itself.
Am sure I am missing something can someone help me to find the cause? I want the call to go out tof the remote gateway.
Re: TEHO on 7.X
If I follow, you have a route list like this:
RG 1: LocationBGateway
RG 2: StandardLocalRouteGroup
And you have verified that the LocationBGateway is not trying to send the call to the PSTN.
What happens when you call from Location B? Is this gateway/routegroup working for any other calls?
Are you using h323/sip/mgcp? If h323/sip: "debug voice ccapi inout" to see if you are getting call setup from the CUCM. You can also see what dial-peers are hit (or not hit as the case may be).
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Re: TEHO on 7.X
I have all mgcp gateways. Calls work via the gateway when I make calls from loc B.
Nagarajan
Message sent from a Baxter Blackberry Device
Re: TEHO on 7.X
Reset the RL, if that doesn't fix it restart the CCM service.
Please remember to rate helpful responses and identify helpful or correct answers.
197
