TEHO
Hi All,
Just curious does Tail End Hop off works for H.323 gateways??
Do i need to setup any Dial Peers on H.323 gateways for TEHO to work??
Cheers,
Hunt
  • IP Telephony
TEHO
Hunt,
Yes, TEHO works with H.323 gateways.
It is possible you would need to configure dial peers to support TEHO. The degree of configuration would depend on your specific requirements and environment.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
TEHO
Hi Bill,
Thanks so much for your reply.
Would it work if i just transform the numbers in the Route Group to match the appropriate remote site route group and the central site route group??
Cheers,
Hunt
TEHO
this should give you a good idea about TEHO
https://learningnetwork.cisco.com/docs/DOC-1362
183
