07-23-2014 11:17 AM - last edited on 03-25-2019 08:30 PM by ciscomoderator
Hello
Questions:
Should I hear tel-co message on an IP Phone if a call that is meant to be long distance is sent to the gateway without a one (1). Currently these calls simply ring until disconnect, but work properly if the user dials a 1, the user expects to get a message from the provider and I am wondering if the SIP trunk between GW and CUCM is not allowing it?
Scenario:
IP Phone --> CUCM (SIP Trunk) --> ISR 2901(PRI) --> PSTN
In CUCM we have a local pattern 9.[2-9]XX[2-9]XXXXXX
If the IP Phone dials a number that is actually a long distance number, which would require a 1, but they dial it as a 10 digit local number, the call gets to the gateway and IP Phone hears ringing but it, rings until it eventually disconnects. At this point I believe the gateway is sending a cause code back to CUCM and I would expect error message back from the telco informing the caller of the issue, such as "Please dial 1 before a long distance number". Is there a specific setting on the SIP trunk and or Gateway to achieve this?
See Q931 Debug
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838F
Exclusive, Channel 15
Display i = 0xB1, 'London Hydro'
Calling Party Number
UCS5-GW-02# i = 0x2181, '5193334444'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '5191112222'
*Jul 23 15:33:28.363: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8 callref = 0xC3FA
Cause i = 0x80AB28 - Access information discarded
Call State i = 0x01
*Jul 23 15:33:28.411: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xC3FA
*Jul 23 15:33:28.415: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0xC3FA
Cause i = 0x80FF - Interworking error; unspecified
Progress Ind i = 0x8088 - In-band info or appropriate now available
Richard
Solved! Go to Solution.
07-23-2014 03:33 PM
Yes, Early media needs to be turned on the SIP Profile that is associated to the SIP trunk. The setting is SIP Rel 1xx options. It needs to be set for Send PRACK for all 1XX messages. If you have CUCM 7.x , this setting is a service parameter.
07-23-2014 03:33 PM
08-11-2014 08:33 PM
Right On! Thank you both
08-11-2014 10:46 PM
Thanks George that most definately worked!!!
09-07-2015 08:01 AM
Hello Richard, my apologies for sending you this reply through this post I wasn't sure how I can write to you only!!!! Anyway, year ago, you were writing a script for holidays check and got it working. Would you mind sharing some info with me? Specifically, I am hard time understanding Input Mappings/Out Mappings when a sub flow is called. Any help would greatly appreciated. Sorry again--
my email-gary.dubey@gmail.com
sorry everyone....I won't do it again.
