Telecaster table inserting phones
Jeremy Lim
I have encourtered issue inserting 7975 phones using BAT. The error message is below
"Telecaster table may only reference devices that support Cisco Unified IP Phone Services."
I have delete the services on the template and I have no issues on previous attempts to insert the 7975 phones.
Any ideas?
Jaime Valencia
Remove whatever directory URL you have configured on the Phone Template and try again
CSCsv27394
TELECASTER Error 3500 when using BAT Phone Template
java
if this helps, please rate
http://www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
CSCsv27394
java
java
