Community Member
Telephone Security
We are using model 7945 and 9951 Cisco IP Phones.
Is there any security or locked the Telephone?
Michael
Purple
Telephone Security
Hi Michael,
you do this either by implementing Extension Mobility where password is required for login/logout or purchasing 3rd party software [Andtek] for locking phone.
https://supportforums.cisco.com/message/4071697#4071697
regds,
aman
Telephone Security
Generally this is implemented through the use of Exgension Mobility,
Phone will be sitting without an extension, or a basic extension and the user would have to login with a PIN to load his extension configuration. In the same way they would login to unlock their computers. When done people would logout of their EM profiles. You can auto logout at specific amount of time, or schedule times also.
If you want a call by call pin, for sensitive destionations like international calls, you may want to look into FAC (forced autorization access code) which is a CUCM and CME feature.
171
