Telepresence Ex90 configuration of cucme v9.1
mohammed-amjad
I have CUCME Version 9.1  Cisco 2921 Router and i have Telepresence Ex90 How to configure SIP for this.
Aman Soi
Hi Amjad,
It is not supported with CME 9.1
you can refer compatibility matrix for CME 9.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
regds,
aman
[+5] for Aman, just wanted to add that this option is not available even in CME version 10.0. You can use CUCM or VCS as the call control server. Please check the following link as well
https://supportforums.cisco.com/thread/2241892
Manish
Thank you so much Mr. Amaan may i know which version of cme i have use to configure Ex90?
Hi Manish,
thanks for updating one level up for CME 10.0 [+5]
regds,
aman
