TelePresence
Vysakh Sundar
There is a confusion in setting a telepresence actually my BOQ includes
Telepresence EX-60
Presence Sx20
Cisco Virtual VCS control
Cisco Virtual VCs express way
Management suite application with jabber license
Precision HD camera
Mcu 5310
UCS c-series server
help me creating a visio
testeven
I would recommend to check the TP design guide below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/design/guides/videodg/vidguide.pdf
It comes with a Video Architecture diagram which might help you build your own according to your customer's needs.
Also you can just google telepresence video design images and you'll get some examples.
Tere.
Please rate helpful posts!
Regards, Tere. If you find this post helpful, please rate! :)
6 Replies 6
George Thomas
Level 10
Level 10
Not sure what the question is but we wont be able to create a visio for you without knowing more details. I would suggest you contact a Cisco partner or if you have specific questions, feel free to post here.
Please rate useful posts.
can you help me how we will connect all these devices
what is the role of MCU specificaly
The MCU is used for combining (mixing) multiple audio and video streams for video conferencing.
so can i finalize the design as
SX-20 , EX-60 connected to  VCS control
VCS control connected to CUCM, VCS express way
VCS expressway connected to internet cloud
TMS connected to CUCM,VCS control
so where will MCU will be connected ?
Hello
1-If you have regustered video endpoints on CUCM .Cisco MCU , can be integrated with CUCM using SIP trunk.Then you Can configure Route pattern on CUCM to access MCU or AA conference  resources . TMS is used For management and schendule so you will register MCU and your VCS toTMS  .If you have multipoint on your network , which will regiister to VCS , so you have to integrate between MCU and VCS using H323 or SIP to control . For more information , kindly find the below:-
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Multiway_Deployment_Guide_X7.pdf
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/admin_guide/Cisco_TMS_Admin_Guide_14-1.pdf
4-Kindly find the below link which is very useful to get a brief about all solution.
http://www.zebrac.com/zebra/common/PreviewDocument.ashx?itemId=1053&refItemId=T470DOCUMENTS&refTableId=470&language=EN
Note: Your above devices will be inside your network , except your expressway will be on DMZ area .
please rate all useful information
testeven
Tere.
