Teleworker UC520 / SR520
Hi i recently had a new UC520 system installed and my installer is having a terrible time (as am i) getting teleworker installed. i have opened numerous tickets with Cisco and its seems no one has the complete answer. Does anyone have any detailed information to set this up ? Can this be done via a GUI ? any information would be appreciated.
Thank you
Hall of Fame Super Gold
Re: Teleworker UC520 / SR520
Forget the GUI, professional configuration is done with CLI exclusively.
Key to success is having a proper VPN setup.
Then, you want to mention the specific problem here with full details. Be reassure lot of people uses remote phones without any problem.
So is there documentation on where to start ?
To be honest with you, documentation is a bit confusing, because there are hundreds different ways to configure a VPN including certain cases in which a non-cisco VPN is used.
In any case, once you have the VPN 100% working, then it's just a matter of installing IPCP on a PC and registering as a ephone into CME.
You can also consider hiring a professional for the VPN job that is crucial.
213
