Temporary failure (with trace detail)
Hi there,
Now I think I can't go any further by myself
I have this scenario:
[Siemens PBX]--ISDN BRI MGCP--[myRouter3845]--(WAN)--[CUCM 8.5]--MyIPPhone
When I place the call from MyIPPhone to the Siemens extension, it works... If the Siemens extension calls me, I pick up the call and talk for about 4s.. then the call is dropped. As far as I could see in the traces, the CUCM sends a disconnect message to the router. But I cannot see the reason for that.
Any help?
Thanks.
Andrei.
Disconnection Message
Outbound Q931 DISCONNECT message to 10.211.3.40 at timestamp 07/27/2012 13:27:38.615
DISCONNECT, pd = 8, callref = 0x81, Message Size = 8 bytes
Cause i = 0x80A9 - Temporary failure
Entire Message:
010:  08 01 81 45 08 02 80 A9
Now, the detailed messages
13:27:38.615 | |*^*^*
13:27:38.615 |Out Message -- BriDisconnectMsg -- Protocol= BriProtocol|*^*^*
13:27:38.615 |Ie - Q931CauseIe IEData= 08 02 80 A9 |*^*^*
13:27:38.615 |MMan_Id= 0. (iep=  0 dsl= 9001 sapi=  0 ces=  0 IpAddr=2803d30a IpPort=2427)|*^*^*
13:27:38.615 |IsdnMsgData2= 08 01 81 45 08 02 80 A9 |*^*^*
13:27:38.618 |MGCPBhHandler - Sending BhHdr: 0004 0000 0010 9001 0001 0008|1,100,173,59994.1^*^*
13:27:38.618 |cdrWrite PER RR, orig = 0, lrn = 0, current = 0|1,100,173,59994.1^*^*
13:27:38.618 |ConnectionManager - wait_AuDisconnectRequest(18733429,18733430),disconnectType(1), IFHandling(0,0)|1,100,173,59994.1^*^*
13:27:38.618 |EnvProcessCdr::wait_DbCdrReq|1,100,173,59994.1^*^*
13:27:38.618 |EnvProcessCdr::wait_DbCdrReq DETAILED Entries 461922, Inserts 218662,             ZeroCalls 243260, StartRecords 0, Default 0|1,100,173,59994.1^*^*
13:27:38.618 |EnvProcessCdr::formatCdrData|1,100,173,59994.1^*^*
13:27:38.618 |ConnectionManager - storeMediaInfo(18733429): EXISTING ENTRY DISCOVERED, size=83|1,100,173,59994.1^*^*
13:27:38.618 |ConnectionManager - storeMediaInfo(18733430): EXISTING ENTRY DISCOVERED, size=83|1,100,173,59994.1^*^*
13:27:38.618 |MediaCoordinator - wait_AuDisconnectRequest,CI(18733429,18733430),IFCreated(1,1)|1,100,173,59994.1^*^*
13:27:38.618 |MediaCoordinator - wait_AuDisconnectRequest - sending disconnect to MediaManager(218947)|1,100,173,59994.1^*^*
13:27:38.618 |MediaManager(218947)::wait_AuDisconnectRequest, mCleanupPreallocatedMTP=0|1,100,173,59994.1^*^*
13:27:38.618 |MediaManager(218947)::wait_AuDisconnectRequest, mrid(0,0) ci(1873342918733430) size(1), dt(1)|1,100,173,59994.1^*^*
13:27:38.618 |MediaManager(218947)::wait_AuDisconnectRequest, StopSession,disconn MX(130,223076) mrid (0 0), IFHandling(0,0)|1,100,173,59994.1^*^*
13:27:38.618 |MediaExchange(223076)::wait_Disconnect, dt=1,stReason=0,IFHandling(0,0)|1,100,173,59994.1^*^*
13:27:38.618 |MGCPInterface(90209) - isGClearCall - return false, gClearSupported:0, mpeerxfermode:13|1,100,173,59994.1^*^*
13:27:38.618 |DET-H245Interface-(59994)::handleStopStreaming, stopStreamingRecdInWaitForCapExchgState=0|1,100,173,59994.1^*^*
13:27:38.618 |MGCPHandler send msg SUCCESSFULLY to: 10.211.3.40
MDCX 491422 BRI/S0/SU1/P1/1@myRouter3845 MGCP 0.1
C: D0000000011dd975000000F580000001
I: 5A
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
Joseph Martini
Can you post some of the CCM trace prior to the disconnect being sent out please?
