Temporary install CUCM7.1.5 / Unity Connection 7.1.3 on UCS C220M3
We have a IPT Migrate project, The CUCM version is 7.1.5 and the Unity Connection version is 7.1.3
We will upgrade the system to 8.6(2) version.
My question is:
I know we can export/import the DB from customer IPT system to lab system, but can we temporary build the CCM7.1.5 and CUC7.1.3 on UCS-C220M3S?
It means we can import the DB into UCS-C220M3 (IPT 7.1.X) and then make a L2 upgrade to 8.6.
Thanks!
1 REPLY
Hall of Fame Super Silver
This would be supported if you were going to version 9 under Cisco's Drive to 9 program which allows you now to install version 6.1, 7.1 in vmware and perform supported upgrade. Though there is no reason why not to do the same for version 8.6, check out release notes for version 9.1.2 for details. The important step is after you upgrade to your desired version to take DRS backup, rebuild the vmware from scratch with the desired version and restore from DRS, this ensures partition alignment.
HTH,
Chris
146
