Test IP phone with, and without QoS
  Hi all!
  I would like to try this:
1 - Connect an IP phone in a switch (without QoS) and generate a lot of traffic in the trunk to force the voice to interruptions.
2 - Connect an IP phone in a switch (with QoS) and with the same traffic verify that the QoS works fine.
But the step 1 failed. Not cut of voice, only a little bit of delay. I generate traffic with ping in 4 switch and SolarWinds WAN killer.
ping 192.168.50.11 repeat 2100000000 size 18024
(192.168.50.11 is the IPphone into the switch)
I check the traffic in the trunk with Cacti (see attachment).
¿What i doing wrong?
Thanks!
Martín.
Everyone's tags (1)
What's the full topology for
What's the full topology for the phone call?  Just 2 IP Phones on the same switch calling each other?
   Hi Brian, see these
  Hi Brian, see these attachment.
 SW4, SW1, SW2 with QoS configured.
 SW3, SW5 with out QoS
Both phone on the same vlan.
Thanks for reply
So for audio quality between
So for audio quality between the phones, we only have to worry about the switches since both phones are on the same VLAN.  What model switches are these?
The switches by default should have different input/output queues it places things into based on DSCP/CoS.  This could be resulting in the default settings being okay enough.  Can you set WAN killer to tag the packets with a DSCP value of 46(EF)?  That may help in exhausting the queues being used for the voice traffic and causing the packet loss you're trying to show.
   Hi again, the model of
  Hi again, the model of switch:
SW3 and SW5 are WS-C2960-24TT-L    12.2(55)SE8
SW4, SW1, SW2 are WS-C2960G-24TC-L    12.2(55)SE8
I can't set WAN Killer for tagging packets. I don't know what to do.
Try using something like D
Try using something like D-ITG as referenced here- https://learningnetwork.cisco.com/thread/7763
It should do the same as WAN Killer and allow you to set DSCP.
   I already saw these link:
  But i can´t get work D-ITG, i'll try again.
97
