Testing 5.1 CM backups
Does anyone know of an effective way to test 5.1 CM backups? I would prefer that we don't build a test server just for this purpose but if that is the only way to do it I guess we will have to.
1 REPLY
Re: Testing 5.1 CM backups
if it's fresh installation and you perform restore from a backup, you need to install locale on your CM system before or after restore, because restore process just copies files, it does not update database with installed locale information.
- if it's a restore applied on the running system make sure that you already have installed locales which correspond to the CM version.
93
