Testing a DRS restore?
Good Morning NetPros,
Has anyone successfully tested a DRS restore, CUCM version 7.1.3, without affecting production? I would like to be confident that the DRS backups generated are actually going to work if a restore procedure is ever needed. Now that I have had consistent backups for a good amount of time, this is something I'd be curious if anyone has done.
Would I be able to perform a restore on production servers without requiring services to restart? Would it require a restart of the server?
It's probably best to perform this on a test system, however I am not afforded the luxury of that : )
Shane
1 ACCEPTED SOLUTION
Re: Testing a DRS restore?
You cannot do this on a production system without affecting service.
1) It requires a reboot
2) You lose any data from when the backup was performed and then restored
If you do not have a test system, I would recommend getting a fresh backup in the evening then doing an immediate restore and getting everything back up and running.
Yes, you should typically do this on a test system.
Hailey
Please rate helpful posts!
Hailey
Thanks David, that's the response I was looking for. I appreciate your time.
Shane
154
