TFTP File Management and Services URL for Cisco Phone question
WHen I uploaded some sample.xml file to TFTP Directory -> /
<br />
<br />What URL should I use to get this as service from Cisco Phone?
<br />
<br />
<br />This link doesn't work:
<br /><font color=red>http://CUCM_IP:8080/ccmcip/sample.xml</font>
<br />
<br />
Re: TFTP File Management and Services URL for Cisco Phone questi
you need to load that into a web server, not a TFTP server
java
if this helps, please rate
java
www.cisco.com/go/pdi
Is it possible to remain this file on CUCM? It's principle that I shouldn't change IP address of service.
no, you do not get access to the tomcat folder so you cannot add files to the CUCM web server. you need a separate web server
same as with the idle url
java
java
150
