Community Member
TFTP server on 2691 router
Dear Cisco techs,
Can someone please guide me to link on how to set up TFTP on 2691 router
When I type conf t.
tttp-server flash: is does nothing
Or tftp-server gives unrecognized command
Have searched quite a few places. Leads to various links but nothing conclusive. One directed me to a tftpdnld command but is for ios image updating only.
Want to update flash: with more files for ip phone
Why does cisco make this so difficult?
Thanks again :)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
What happens if you do this:
config t
tftp flash:filename.extension
end
It's suppose to be "tftp
It's suppose to be "tftp-server flash:filename.extension".
Purple
Hi John, You can also refer
Hi John,
You can also refer the link
https://supportforums.cisco.com/document/9541/how-configure-cisco-router-tftp-server
regds,
aman
Community Member
Is this for phone firmware as
Is this for phone firmware as well as link above only shows for ios images.
When I do tftp-server flash: filename.extension ..comes back with unrecognised command
This should work for any file
This should work for any file.
You're getting error message?  Hmmmm ... Are you doing this is global configuration mode?
Community Member
No . Thanks for prompt
No . Thanks for prompt response Leo..:)
config t
end
Community Member
Thanks Leo. I wasn't in
Thanks Leo. I wasn't in global config mode. All this cisco stuff is very interesting and at time challenging. LUV IT
One more question if I may.
Sh clock keep referring back to year 2002 after being updated. I unplug router. Goes back to 2002. How can I keep it as current date?
NTP server has been set but not synchronised.
Does NTP server control the sh clock command output?
63
