Community Member
TFTP
I am not able to edit the TFTP server key in my IP phone ( want to register it to another CCM). After pressing **#, the message is " that key is not active here". This used to work in my previous organization. Anything I need to change anywhere?
1 ACCEPTED SOLUTION
Re: TFTP
Have you checked "DHCP Enabled" field. It should be set to "No" to be able to edit IP/TFTP details
Re: TFTP
Community Member
Re: TFTP
Anand,
Thanks a lot. It's fixed now. Have a nice day.
Abhijit Das.
120
