The IP Phone does not get the calls from the FXO
Hi Guys
I have a problem, for incoming calls using FXO the call does not get to IP Phones. I´m trying to configure but has been useless.
***********Here part of the show run:
trunk group SalidaLocal
 hunt-scheme round-robin
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 10.175.200.6
  ipv4 10.175.200.7
  ipv4 10.175.232.6
  ipv4 10.175.236.6
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol pass-through g711ulaw
 h323
 sip
  registrar server expires max 1200 min 300
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
interface FastEthernet0/0
 description ***Conexion WAN***
 ip address 10.175.190.2 255.255.255.252
 duplex auto
 speed auto
interface Integrated-Service-Engine0/0
 no ip address
 shutdown
interface FastEthernet0/1/0
 switchport voice vlan 2
 spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Vlan1
 ip address 10.175.90.1 255.255.255.0
interface Vlan2
 ip address 10.175.231.1 255.255.255.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.175.231.1
ip route 0.0.0.0 0.0.0.0 10.175.190.1
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
 trunk-group SalidaLocal
 connection plar 3810
 description SalidaLocal
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control
 description Music On Hold Port
mgcp profile default
dial-peer voice 3811 voip
 preference 1
 destination-pattern 3810
 progress_ind setup enable 3
 progress_ind progress enable 8
 session target ipv4:10.175.200.7
 incoming called-number .
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 codec g711alaw
 ip qos dscp cs5 media
 ip qos dscp cs5 signaling
 no vad
*********CCH323 SPI: H225 State Machine tracing is enabled (filter is OFF)
*********CCH323 SPI: H245 State Machine tracing is enabled (filter is OFF)
*Sep  3 20:25:51.759: //18/554328FA802A/H323/cch323_call_setup_normal:  SETUP_NTF_TIMER is not running. Continue processing.
*Sep  3 20:25:51.763: //18/554328FA802A/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
*Sep  3 20:25:51.763: //18/554328FA802A/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
*Sep  3 20:25:51.763: //18/554328FA802A/H323/check_qos_and_send_setup: Setup ccb 0x89E0DF98
*Sep  3 20:25:51.763: //18/554328FA802A/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
*Sep  3 20:25:51.763: //18/554328FA802A/H323/idle_fsSetup_hdlr: Setup ccb 0x89E0DF98
*Sep  3 20:25:51.763: //18/554328FA802A/H323/generic_send_setup:
generic_send_setup: is_overlap = 0, info_complete = 0
*Sep  3 20:25:51.763: //18/554328FA802A/H323/generic_send_setup: ====== PI = 3
*Sep  3 20:25:51.763: //18/554328FA802A/H323/generic_send_setup: Send infoXCap=144, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
*Sep  3 20:25:51.763: //18/554328FA802A/H323/generic_send_setup: src address = 10.175.231.1; dest address = 10.175.200.7
*Sep  3 20:25:51.767: //18/554328FA802A/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
*Sep  3 20:25:51.767: //18/554328FA802A/H323/run_h245_iwf_sm: received IWF_EV_FASTSTART while at state IWF_IDLE
*Sep  3 20:26:06.767: //18/554328FA802A/H323/cch323_h225_send_release: Cause = 102; Location = 0
*Sep  3 20:26:06.767: //18/554328FA802A/H323/cch323_h225_send_release: h225TerminateRequest: src address = 179300097; dest address = 10.175.200.7
*Sep  3 20:26:06.767: //18/554328FA802A/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
*Sep  3 20:26:06.767: //18/554328FA802A/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
*Sep  3 20:26:06.767: //18/554328FA802A/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
*Sep  3 20:26:06.767: //18/554328FA802A/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
****************CCAPI: debug voip ccapi inout is ON (filter is OFF)
*Sep  3 20:27:09.319: //-1/837F1995802F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3810
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Sep  3 20:27:09.319: //-1/837F1995802F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8870B888, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3810(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=SalidaLocal, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Sep  3 20:27:09.319: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep  3 20:27:09.319: :cc_get_feature_vsa malloc success
*Sep  3 20:27:09.319:  cc_get_feature_vsa count is 1
*Sep  3 20:27:09.319: :FEATURE_VSA attributes are: feature_name:0,feature_time:2260898832,feature_id:19
*Sep  3 20:27:09.319: //19/837F1995802F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3810(TON=Unknown, NPI=Unknown))
*Sep  3 20:27:09.323: //19/837F1995802F/CCAPI/cc_process_call_setup_ind:
   Event=0x886DCB38
*Sep  3 20:27:09.323: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 3810
*Sep  3 20:27:09.323: //19/837F1995802F/CCAPI/ccCallSetContext:
   Context=0x86C41FE8
   >>>>CCAPI handed cid 19 with tag 0 to app "_ManagedAppProcess_Default"
*Sep  3 20:27:09.323: //19/837F1995802F/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Sep  3 20:27:09.327: //19/837F1995802F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=3811, Params=0x86C43440, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Sep  3 20:27:09.327: //19/837F1995802F/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=3810, Called Number=3810, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=837F1995-32DF-11E4-802F-C8032C336814, Outgoing Dial-peer=3811
*Sep  3 20:27:09.327: //19/837F1995802F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3810
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Sep  3 20:27:09.327: //19/837F1995802F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x884B2F28, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3810(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3811, Call Count On=FALSE,
   Source Trkgrp Route Label=SalidaLocal, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
*Sep  3 20:27:09.327: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep  3 20:27:09.327: :cc_get_feature_vsa malloc success
*Sep  3 20:27:09.327:  cc_get_feature_vsa count is 2
*Sep  3 20:27:09.327: :FEATURE_VSA attributes are: feature_name:0,feature_time:2260898608,feature_id:20
*Sep  3 20:27:09.327: //20/837F1995802F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Sep  3 20:27:09.327: //20/837F1995802F/CCAPI/ccCallSetContext:
   Context=0x86C433F0
*Sep  3 20:27:09.327: //19/837F1995802F/CCAPI/ccSaveDialpeerTag:
*Sep  3 20:27:24.331: //20/837F1995802F/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x884B2F28, Call Id=20
   Call Entry(Responsed=TRUE, Cause Value=18, Retry Count=0)
*Sep  3 20:27:24.331: //19/837F1995802F/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Sep  3 20:27:24.331: //20/837F1995802F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=20
*Sep  3 20:27:24.331: //20/837F1995802F/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=18)
   Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
*Sep  3 20:27:24.331: //20/837F1995802F/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Sep  3 20:27:24.335: //20/837F1995802F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x884B2F28, Tag=0x0, Call Id=20,
   Call Entry(Disconnect Cause=18, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Sep  3 20:27:24.335: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep  3 20:27:24.335: :cc_free_feature_vsa freeing 86C29328
*Sep  3 20:27:24.335:  vsacount in free is 1
*Sep  3 20:27:24.335: //19/837F1995802F/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Sep  3 20:27:24.335: //19/837F1995802F/CCAPI/cc_api_get_transfer_info:
Any idea?
TIA
Cristian
I'd start looking into CUCM
I'd start looking into CUCM at this point in time, GW config, inbound CSS, significant digits, transformations, etc.
java
if this helps, please rate
www.cisco.com/go/pdi
Dear JaimeI´ve checked the
Dear Jaime
I´ve checked the CUCM config, CSS Ext and Incoming GW, there not transformations, DP, etc.
Thanks for you answer.
Cristian.
i see that the call is
i see that the call is failing with cause code 18 (no user response).
There is only one dial-peer pointing to a single callmanager, do you have only one callmanager configured.
If there are more servers try adding dial-peers for the other severs as well.
Praveen.
Dear Praveen I added the
Dear Praveen
I added the follow:
 preference 1
 destination-pattern 381.
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 3812 voip
 preference 2
 session target ipv4:10.175.236.6
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 3813 voip
 preference 3
 destination-pattern 9T
 session target ipv4:10.175.232.6
 voice-class codec 1
 no vad
dial-peer voice 900 pots
 direct-inward-dial
 port 0/1/0
This is the CCAPI
*Sep  4 19:04:49.270: //-1/2D69195780E9/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3810
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Sep  4 19:04:49.270: //-1/2D69195780E9/CCAPI/cc_api_call_setup_ind_common:
   Incoming Dial-peer=900, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Sep  4 19:04:49.270: //-1/2D69195780E9/CCAPI/ccCheckClipClir:
*Sep  4 19:04:49.270: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep  4 19:04:49.270: :cc_get_feature_vsa malloc success
*Sep  4 19:04:49.270:  cc_get_feature_vsa count is 1
*Sep  4 19:04:49.270: :FEATURE_VSA attributes are: feature_name:0,feature_time:2260898608,feature_id:107
*Sep  4 19:04:49.270: //107/2D69195780E9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Sep  4 19:04:49.274: //107/2D69195780E9/CCAPI/cc_process_call_setup_ind:
   Event=0x886DD578
*Sep  4 19:04:49.274: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Sep  4 19:04:49.274: //107/2D69195780E9/CCAPI/ccCallSetContext:
   Context=0x86C31B80
   >>>>CCAPI handed cid 107 with tag 900 to app "_ManagedAppProcess_Default"
*Sep  4 19:04:49.274: //107/2D69195780E9/CCAPI/ccCallProceeding:
*Sep  4 19:04:49.278: //107/2D69195780E9/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3811, Params=0x86C307C8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Sep  4 19:04:49.278: //107/2D69195780E9/CCAPI/ccCheckClipClir:
   Destination Pattern=381., Called Number=3810, Digit Strip=FALSE
   Guid=2D691957-339D-11E4-80E9-C8032C336814, Outgoing Dial-peer=3811
*Sep  4 19:04:49.278: //107/2D69195780E9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3810
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Sep  4 19:04:49.278: //107/2D69195780E9/CCAPI/ccIFCallSetupRequestPrivate:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Sep  4 19:04:49.278: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep  4 19:04:49.278: :cc_get_feature_vsa malloc success
*Sep  4 19:04:49.278:  cc_get_feature_vsa count is 2
*Sep  4 19:04:49.278: :FEATURE_VSA attributes are: feature_name:0,feature_time:2260898832,feature_id:108
*Sep  4 19:04:49.278: //108/2D69195780E9/CCAPI/ccIFCallSetupRequestPrivate:
*Sep  4 19:04:49.278: //108/2D69195780E9/CCAPI/ccCallSetContext:
   Context=0x86C30778
*Sep  4 19:04:49.278: //107/2D69195780E9/CCAPI/ccSaveDialpeerTag:
*Sep  4 19:05:04.286: //108/2D69195780E9/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x884B2F28, Call Id=108
*Sep  4 19:05:04.286: //107/2D69195780E9/CCAPI/ccCallReleaseResources:
*Sep  4 19:05:04.286: //108/2D69195780E9/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=108
*Sep  4 19:05:04.286: //108/2D69195780E9/CCAPI/ccCallDisconnect:
*Sep  4 19:05:04.286: //108/2D69195780E9/CCAPI/cc_api_get_transfer_info:
*Sep  4 19:05:04.290: //108/2D69195780E9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x884B2F28, Tag=0x0, Call Id=108,
*Sep  4 19:05:04.290: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep  4 19:05:04.290: :cc_free_feature_vsa freeing 86C29408
*Sep  4 19:05:04.290:  vsacount in free is 1
*Sep  4 19:05:04.290: //107/2D69195780E9/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3812, Params=0x86C343E0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Sep  4 19:05:04.290: //107/2D69195780E9/CCAPI/ccCheckClipClir:
   Guid=2D691957-339D-11E4-80E9-C8032C336814, Outgoing Dial-peer=3812
*Sep  4 19:05:04.290: //107/2D69195780E9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3810
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Sep  4 19:05:04.294: //107/2D69195780E9/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3812, Call Count On=FALSE,
*Sep  4 19:05:04.294: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep  4 19:05:04.294: :cc_get_feature_vsa malloc success
*Sep  4 19:05:04.294:  cc_get_feature_vsa count is 2
*Sep  4 19:05:04.294: :FEATURE_VSA attributes are: feature_name:0,feature_time:2260898832,feature_id:109
*Sep  4 19:05:04.294: //109/2D69195780E9/CCAPI/ccIFCallSetupRequestPrivate:
*Sep  4 19:05:04.294: //109/2D69195780E9/CCAPI/ccCallSetContext:
   Context=0x86C34390
*Sep  4 19:05:04.294: //107/2D69195780E9/CCAPI/ccSaveDialpeerTag:
*Sep  4 19:05:19.298: //109/2D69195780E9/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x884B2F28, Call Id=109
*Sep  4 19:05:19.298: //107/2D69195780E9/CCAPI/ccCallReleaseResources:
*Sep  4 19:05:19.298: //109/2D69195780E9/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=109
*Sep  4 19:05:19.298: //109/2D69195780E9/CCAPI/ccCallDisconnect:
*Sep  4 19:05:19.298: //109/2D69195780E9/CCAPI/cc_api_get_transfer_info:
*Sep  4 19:05:19.302: //109/2D69195780E9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x884B2F28, Tag=0x0, Call Id=109,
*Sep  4 19:05:19.302: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep  4 19:05:19.302: :cc_free_feature_vsa freeing 86C29408
*Sep  4 19:05:19.302:  vsacount in free is 1
*Sep  4 19:05:19.302: //107/2D69195780E9/CCAPI/ccCallDisconnect:
*Sep  4 19:05:19.302: //107/2D69195780E9/CCAPI/cc_api_get_transfer_info:
This is the CCH323 H225:
*Sep  4 19:07:21.434: //114/881ADE9080F5/H323/cch323_call_setup_normal:  SETUP_NTF_TIMER is not running. Continue processing.
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/check_qos_and_send_setup: Setup ccb 0x878F920C
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/idle_fsSetup_hdlr: Setup ccb 0x878F920C
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/generic_send_setup:
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/generic_send_setup: ====== PI = 3
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/generic_send_setup: Send infoXCap=144, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
*Sep  4 19:07:21.438: //114/881ADE9080F5/H323/generic_send_setup: src address = 10.175.231.1; dest address = 10.175.200.7
*Sep  4 19:07:21.442: //114/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
*Sep  4 19:07:36.438: //114/881ADE9080F5/H323/cch323_h225_send_release: Cause = 102; Location = 0
*Sep  4 19:07:36.438: //114/881ADE9080F5/H323/cch323_h225_send_release: h225TerminateRequest: src address = 179300097; dest address = 10.175.200.7
*Sep  4 19:07:36.438: //114/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
*Sep  4 19:07:36.438: //114/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
*Sep  4 19:07:36.442: //115/881ADE9080F5/H323/cch323_call_setup_normal:  SETUP_NTF_TIMER is not running. Continue processing.
*Sep  4 19:07:36.442: //115/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/check_qos_and_send_setup: Setup ccb 0x878F920C
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/idle_fsSetup_hdlr: Setup ccb 0x878F920C
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/generic_send_setup:
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/generic_send_setup: ====== PI = 3
*Sep  4 19:07:36.446: //115/881ADE9080F5/H323/generic_send_setup: Send infoXCap=144, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
*Sep  4 19:07:36.450: //115/881ADE9080F5/H323/generic_send_setup: src address = 10.175.231.1; dest address = 10.175.236.6
*Sep  4 19:07:36.450: //115/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
*Sep  4 19:07:51.450: //115/881ADE9080F5/H323/cch323_h225_send_release: Cause = 102; Location = 0
*Sep  4 19:07:51.450: //115/881ADE9080F5/H323/cch323_h225_send_release: h225TerminateRequest: src address = 179300097; dest address = 10.175.236.6
*Sep  4 19:07:51.450: //115/881ADE9080F5/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
*Sep  4 19:07:51.450: //115/881ADE9080F5/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
The problem continues.
TIA
Cristian
Try running a DNA analyser
Try running a DNA analyser with Gateway incoming CSS and the called number as 3810.
There seems to be a problem with the translation.
Check these.
DN on the phone should be configured as 3810 or if it is something else then there should be a TP converting it to the complete number.
Check if the PT that number is configured in is a part of the gateway incoming CSS.
If there is a TP converting to the complete number then that PT of the TP should be in the gateway incoming CSS.
The next step would be CUCM
The next step would be CUCM traces, the problem appears to be in CUCM, not the GW.
java
62
