The phone keep ringing eventhough the caller hangs up
I have 3825 CME with CUE, when a caller call and the autoattended played and route to whatever extension he want, and the caller hang-up before answering the phone keep ringing with no end.
I tried to configure the FXO to one of extension directly without autoattendant it worked fine “disconnect directly”.
I have attach you “show run” and “debug vpm signal”
1 ACCEPTED SOLUTION
Re: The phone keep ringing eventhough the caller hangs up
If you need the detail screenshot for each steps, you can check this link:
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
Hope this help
You need to enable supervisory disconnect on the fxo port.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dt_fxodt.html
hth
Rick
Try these configuration for disconnect:
voice-port 0/2/0
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
It works on most of my configured FXO voicegateway.
hi,
I have add supervisory command but still ringing, another solution please.
If your configuration is exactly like this:
voice-port 0/2/0
cptone BR
timeouts ringing 5
May be your frequency and cadence is wrong. Please make a custom tone and re-apply it to your voice-port.
For example:
*** please note that the parameters are for Vietnamese telco only ***
voice class custom-cptone vn
dualtone disconnect
  frequency 425 425
  cadence 500 500 continuous
voice-port 0/2/0
supervisory custom-cptone vn
no battery-reversal
timeouts call-disconnect 0
timeouts ringing 5
hi,
sorry for late, but still same  keep ringing.
Note that the frequency and cadence I posted are just example. You need to find exactly what your parameters are.
Method 1: Ask your telco
Method 2: Get it yourself by capture the tone and analyze by some tools like CoolEdit Pro... If you need to do it, please contact me for the steps.
Sorry for late I was in vacation, now could you please help for the step to get the frequency and cadence.
And one more thing is this frequency and cadence effect on caller-id.
Appreciate your help.
Could you please help for the step to get the frequency and cadence.
Follow Nick's tips to capture frequency and cadence in this thread:
https://supportforums.cisco.com/message/1153101#1153101
No.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
Hope this help
600
