The wave files are crashing, instead of playing in the Script
The WAV files were crashing perhaps because of their high bitrate. We’ve since replaced the files but the voice gateway is keeping the previous file in its cache.
Can you please post me the command to clear cache in Voice gateway..
And also can we fix this problem without entering into VGif yes.. pls guide me the steps to do it
If you want someone to help you with this, you need to elaborate. Also, you have to mention the following:
- cucm details (ver, site setup)
- gateway details
- call flow
Hi.
If you want to refresh an audio prompt you need this command:
audio-prompt load flash:filename.ext
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
116
