Third Party SIP Phone registration
I have a Polycom Soundstation IP 6000 that I'm trying to register to our CUCM 8.x server.  Registration keeps getting rejected and I can't figure out what's going on.  I've configured a digest user and associated the name on the phone configuration page.  When looking at the trace files, I see the phone trying to register but I don't see any rejection error messages being sent by CUCM.  I'm sure this is something simple that I am missing.  Below is the output from my trace.
REGISTER sip:172.16.95.245:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.101.255;branch=z9hG4bK3cbd66316433E898
From: "299" <sip:172.16.95.245@172.16.95.245>;tag=E4C1F90F-33B89DFE
To: <sip:172.16.95.245@172.16.95.245>
CSeq: 2 REGISTER
Call-ID: 46867d3a-a986247d-72be99b4@172.16.101.255
Contact: <sip:172.16.95.245@172.16.101.255>;methods="INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER"
User-Agent: PolycomSoundStationIP-SPIP_6000-UA/3.0.4.0061
Authorization: Digest username="polycom1", realm="ccmsipline", nonce="VseOAqA6w4Hx97MRe2laVKlB28JbATjj", uri="sip:172.16.95.245:5060", response="4d8ba00249e1786c05222a81afb46bef", algorithm=MD5
Max-Forwards: 70
Expires: 3600
Content-Length: 0
|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Info/0x0/ccsip_spi_get_msg_type returned: 2 for event 1|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0x0/context=(nil)|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Info/0x0/Checking Invite Dialog|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Info/0xb45537c0/*****CCB found in UAS Request table. ccb=0xb45537c0|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0x0/Subsq Transaction Address 172.16.101.255,Port 5060, Transport 1, SentBy Port 5060|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0xb45537c0/Sending INFO Response to the transport layer|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0xb45537c0/msg=0xb4589540, addr=172.16.101.255, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=(nil)|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0xb45537c0/Proceedable for sending msg immediately|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0xb45537c0/switch transport is 0|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Transport/0x0/Posting send for msg=0xb4589540, addr=172.16.101.255, port=5060, connId=0 for UDP|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/SIPHandler/ccbId=0/scbId=0/findTrunkInfoByAddr: Cannot find the SIP Trunk with Name=172.16.101.255, Source Port=5060, IpAddress Type=0|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/SIPHandler/ccbId=91/scbId=0/findDevicePID: Routed to SIPStationInit|1,100,213,1.181^172.16.101.255^*
09:19:01.701 |//SIP/Stack/Event/0xb45537c0/
ccsip_api_register_ind return value : SIP_SUCCESS
09:19:01.701 |//SIP/Stack/States/0xb45537c0/0xb45537c0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)|1,100,213,1.181^172.16.101.255^*
09:19:01.702 |CcmCcmdbHelper::getProcessConfigGivenProcessnodeParamnameService - Value of DeviceMobilityMode from process config table is (0)|*^*^*
09:19:01.707 |GetMaxCallForDevice: cannot find entry in ProductSupportsFeature table for product 273 and protocol 11feature SUPPORTS_FEATURE_RESTRICT_MAX_CALLS|*^*^*
09:19:01.707 |GetMaxCallForDevice: cannot find entry in ProductSupportsFeature table for product 273 and protocol 99feature SUPPORTS_FEATURE_RESTRICT_MAX_CALLS|*^*^*
09:19:01.707 | SIPSecurity::decrypt hex password = "eca7d4ee66e70bdaac7d849fda77f0756de140425fc368b8fca0d4cf398c492e" , ecnrypted len 32 |*^*^*
09:19:01.707 |getMaxAuthnameLenFromModel: cannot find entry in ProductSupportsFeature table for model 374 and protocol 11 feature SUPPORTS_FEATURE_MAXIMUM_AUTHNAME_LENGTH|*^*^*
09:19:01.707 |getMaxAuthnameLenFromModel: cannot find entry in ProductSupportsFeature table for model 374 and protocol 99 feature SUPPORTS_FEATURE_MAXIMUM_AUTHNAME_LENGTH|*^*^*
09:19:01.707 |SIPSecurity::verifyAuthResponse: cred.username=polycom1, cred.password=456, auth_hdr.realm=ccmsipline, aut_hdr.nonce=VseOAqA6w4Hx97MRe2laVKlB28JbATjj|*^*^*
09:19:01.707 |getMaxCallForDeviceFromModel: ProductSupportsFeature table entry for model 374 and feature SUPPORTS_FEATURE_MULTIPLE_CALL_DISPLAY has deviceprotocol = 11 maxcalls = 16|*^*^*
09:19:01.707 |<MN::Directory Number><MV::299>|1,100,213,1.181^*^*
09:19:01.707 |EndPointTransientConnection - An endpoint attempted to register but did not complete registration Connecting Port:5060 Device name:SEP0004F2E446B1 Device IP address:172.16.101.255 Protocol:SIP Device type:374 Reason Code:7 Registering SIP User:172.16.95.245 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:MaplesCCMPUB|AlarmSEP0004F2E446B1^*^SEP0004F2E446B1
09:19:01.708 |//SIP/Stack/Info/0x0/ccsip_spi_get_msg_type returned: 3 for event 42|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Info/0xb45537c0/Response Container Holder is above threshold...trimming|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Info/0xb45537c0/Associated container=0xb3c177f0 to REGISTER Response 404|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Transport/0xb45537c0/Sending INFO Response to the transport layer|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Transport/0xb45537c0/msg=0xb4589540, addr=172.16.101.255, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0xa106e72|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Transport/0xb45537c0/Proceedable for sending msg immediately|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Transport/0xb45537c0/switch transport is 0|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/Transport/0x0/Posting send for msg=0xb4589540, addr=172.16.101.255, port=5060, connId=0 for UDP|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,213,1.181^172.16.101.255^*
09:19:01.708 |//SIP/Stack/States/0xb45537c0/0xb45537c0 : State change from (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)|1,100,213,1.181^172.16.101.255^*
09:19:10.163 |Cnf Received: processnodeservice U 66c9cf09-914e-4025-a2fc-73a554b50db5, size(1198) tracelevel(1/127) usercategories(1309183/393216) |0,0,0,0.0^*^*
09:19:10.169 |ProcessCnf N: processnodeservice U 66c9cf09-914e-4025-a2fc-73a554b50db5, size(1198) tracelevel(1/127) usercategories(1309183/393216) |0,0,0,0.0^*^*
09:19:10.169 |doGroupReset: checking for group reset on table processnodeservice|0,0,0,0.0^*^*
09:19:10.169 |DbChangeNotify::SendDbChangeProcessConfig|0,0,0,0.0^*^*
09:19:12.377 |dBProcs - setPkidOfClusterId() starts|*^*^*
09:19:12.377 |setClusterPkId to 195a3d67-4470-4f89-a1b9-b4c159043416|*^*^*
09:19:12.377 |dBProcs::configSdlLinks()|*^*^*
09:19:12.377 |configCHAC: 172.16.95.246 already in CHAC|*^*^*
09:19:12.377 |configCHAC: 172.16.95.245 already in CHAC|*^*^*
09:19:33.723 |//SIP/SIPHandler/ccbId=0/scbId=0/wait_SIPTimer: TimerExpired type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/Removing call id 5b|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0x0/Context for key=[90] removed.|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_REMOVE_TRANSACTION value=32000 retries=0|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/****Deleting from UAS Request table.|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/Deleting from table. ccb=0xb45537c0 key=46867d3a-a986247d-72be99b4@172.16.101.255172.16.95.245E4C1F90F-33B89DFE|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/****Deleting from UAS Response table.|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/There are 0 events on the internal queue that are going to be free'd|1,100,213,1.181^172.16.101.255^*
09:19:33.723 |//SIP/Stack/Info/0xb45537c0/Freeing ccb b45537c0|1,100,213,1.181^172.16.101.255^*
09:19:43.064 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 541 from 172.16.101.255:[5060]:
Via: SIP/2.0/UDP 172.16.101.255;branch=z9hG4bKcfabcc022044C025
From: "299" <sip:172.16.95.245@172.16.95.245>;tag=1600C659-F826B020
CSeq: 1 REGISTER
Call-ID: b83f2ebc-7e3301f7-dc152b46@172.16.101.255
Max-Forwards: 70
Expires: 3600
Content-Length: 0
Re: Third Party SIP Phone registration
Hello Charles,
Please find attached a PDF document which provides you steps to configure a 3rd party SIP phone. Could you please verify the configuration to make sure everything is correct. Many a time, it is a simple configuration issue.
If it still fails, please collect detailed CM sdi/sdl traces, while enabling 'SIP stack trace' and 'SIP call processing trace' on the trace configuration page.
Cheers,
Vajrender
HI Vajrender;
I want to thank you because you solved my problem ........
Hi Charles,
Did you get this to work? i am having same issue.
Mohammed
4173
