Third Party Voice Mail support for CCM 4.1
We do not want to spend heavily on the Unity Voice Mail System.
Are ther any 3rd part Voice Mail system which will work with CCM 4.1 or CCM 5.1 ??
Re: Third Party Voice Mail support for CCM 4.1
You can use SMDI integration from Callmanager to existing third party VM solutions if you have one.
Dear friend,
The existing set up is of Siemens PBX. This has a Voice Mail solution compring of 8 analog port through a box called VMPro from ITS telecon . http://www.its-tel.com/
We are now implementing CCM 4.1 . We would like this whole set up now to move over to IPT from CISCO.
When you mention SMDI Integration, can you briefly help us with methodology. We could take it from there.
In the features it does mention that it support In-Band SMDI Integration
(In-band DTMF integration & out-band serial port RS-232, SMDI integration Yes )
So Ilook forward to hearing from you soon
Additionally, we would be junking the Siemens PBX
From the documentation, I understand that we will have to connect the COM Port of the server to the COM Port of the VM Box.
However the analog lines, will necessiate the need to retail the PBX.
Is there a way , wherin we could use without the PBX ???
219
