Community Member
this service is not compatible with this call
Hey,
I hope someone can help me, my customer says when try to dial a 11 digit normal number in the UK they receive a message as the title.
No special number just a normal 11 digit but others work normally.
its CUCM
Please rate the post
Shibly Ibrahim
Please rate the post Shibly Ibrahim
Everyone's tags (3)
You get that when the far end won't accept a voice call, only an ISDN data call.
GTG
Please rate all helpful posts.
Community Member
Re: this service is not compatible with this call
Hey,
Thanks for the quick response. So it is not a configuration issue on my end is it?.
Because theyw ere using an analog phone system with dass before migrating to CUCM with the dass lines converted to ISDN30. They say they didnt have the issue before
Shibly Ibrahim
If it's only occuring on one destination number, it has to be the other ends problem. Can you dial that number from, say, a POTS or mobile line?
GTG
Community Member
Hey Gordon,
Customer faced with few numbers but not all. It works from Mobile and any other line
Shibly Ibrahim
I'm out of ideas, sorry.
Only thing I can suggest is to do a debug isdn q931 on the gateway and see if you can spot anything in the ISDN messages for one of these failed calls.
GTG
Community Member
Hey,
It looked like a normal clearing. The logs attached on my first post.
A weird message i noticed was something like AA *clear
Shibly Ibrahim
1450
