Tie Unity VM box to Unity DL
balitewiczp
Level 2
Level 2
I have a unity DL and I wanted to attach a mailbox to it. Would I first add a subscriber to the dl, and then add a mbox to the subscriber? thanks
oh yea I wanted to post that a unity subscriber already has a mailbox. exchange mailstore/inbox is where voice mail is delivered to.
rlp
7 Replies 7
Brandon Buffin
So, you have a public distribution list that you want to add another member to? First, setup the new subscriber. Then in Unity admin, go to the PDL. Click Members in the left hand pane. Click the Add radio button. Under "Type a subscriber name to find", type all or part of the subscriber name. Click Find. Choose the subscriber. Click "Add to list".
Hope this helps. If so, please rate the post.
Brandon
I have a request to add a voice mail box to a unity DL. I was asking if I had to add a subscriber to the DL, and then add a mailbox to the subscriber.
Or is there another way to add a VM box to a unity DL. thanks
You will need to first create the subscriber and then add this subscriber to the PDL. When you create a subscriber, you are creating a mailbox as well.
Brandon
this is the same question as Unity to AD Distribution list.
and the answer tha Brandon has is the same as mine so I guess I am right.
rlp
rlp
Yes, you are correct. Thanks for your help
Happy to help and Brandon is a great resource too.
rlp
