Time Calls
My customers wants same extension does calls with 5 minutes (max). It's possible on CUCM 6 or 7 to configure max time of calls?
Peterson
1 ACCEPTED SOLUTION
Re: Time Calls
No and Yes
You can't do this for some phones
Yes you can limit the call time for EACH AND EVERY SINGLE CALL, it's all or nothing.
This has been asked many times before, PLEASE search NetPro for answers.
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Re: Time Calls
No and Yes
java
java
115
