Community Member
Time displayed on 7970 is incorrect
hi
I'm using the CME4 , the time displayed on the 7940 is correct ,while on 7970 is wrong.what is the problem?
thanks very much!
Silver
Re: Time displayed on 7970 is incorrect
what timezone do you have set in Callmanager?
Have you tried setting local timezone?
Ajaz
Silver
forgot to mention - timezone under tepehony-service.
Ajaz
Community Member
Are both of these devices in the same device pool?
-Shikamaru
Silver
hi
sometimes when u do change time zones without success u have to finally to upgrade 7970 firmware to a newer version
hth
134
