When you export CDR's to a server in order to manage it, the time that appears is the "current time" of the CallManager (UTC time). I'd like it appears the "local time" of the CallManager. Is it possible? What do I have to configure? Thanks,
no it's not possible, all those records have UTC time and you cannot change that, you need to do the conversion
javalenc
if this helps, please rate
java
