05-07-2008 03:14 AM - edited 03-15-2019 10:30 AM
When you export CDR's to a server in order to manage it, the time that appears is the "current time" of the CallManager (UTC time). I'd like it appears the "local time" of the CallManager. Is it possible? What do I have to configure? Thanks,
Solved! Go to Solution.
05-07-2008 06:32 AM
no it's not possible, all those records have UTC time and you cannot change that, you need to do the conversion
javalenc
if this helps, please rate
05-07-2008 06:32 AM
javalenc
