Time in CDR's
When you export CDR's to a server in order to manage it, the time that appears is the "current time" of the CallManager (UTC time). I'd like it appears the "local time" of the CallManager. Is it possible? What do I have to configure? Thanks,
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Time in CDR's
no it's not possible, all those records have UTC time and you cannot change that, you need to do the conversion
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Re: Time in CDR's
javalenc
java
116
