Y W
Time is not correct in CME even though it is right on the router it runs from
Hi all,
We have a 2911 that is running CME on top of. The router time is correct but within the CME GUI it is one hour fast. I checked all the setting with timezone and others and it seems to be correct.
In the GUI i tried to change the time and it will just revert whenever I hit apply. I enabled the setting that allows change time in GUI.
Please see attached
any suggestions would be greatly appreciated.
Everyone's tags (2)
Silver
Could you try:conf ttelephony
Could you try:
conf t
telephony service
time-zone ... command
HTH,
Dragan
HTH, Dragan
Dragan is right,Please check
Dragan is right,
Please check a few syntax examples: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_t1ht.html#wp1056604
Y W
Hi,I did enter the time-zone
I did enter the time-zone info under the telephony-service configuration mode. just to be sure i did it again.
same effect, the router from cli will display the correct time, the phones will display the correct time, but if you goto http://routerip/ccme.html and click on system the time is 1 hour faster.
unity which syncs time from this router (set as ntp master) will also have timestamp 1 hour fast.
57
