Time is off on VoIP phones....
omgjames1
so i have this case open with TAC for about a week and they cant seem to figure it out....
all of the VoIP phones in the cluster were 4 minutes slow on Thursday (2/12) as of today they are 7 minutes slow.
this just started happening last week. We use an NTP server pointed to the US Navy master clock. However the PC's show the correct time they are pointed to the same server.
I have no idea what is going on but it is driving me nuts.
-J
5 Replies 5
Tommer Catlin
Check the times between subscriber and publisher. If they do not match, that is your problem. The dbreplication is off and its throwing the time off.
you can also run a quick test. Create a Device Pool with only the Publisher in it. Place a couple phones in that device pool. Does the time change?
htluo
Level 9
Level 9
1) Where the phones are registered with? (which CUCM server).
2) SSH to that CUCM server and type "utils ntp status". Paste the screen output here.
Some tips on NTP:
http://htluo.blogspot.com/2009/02/ntp-network-time-protocol.html
Michael
ntpd (pid 7545) is running...
remote refid st t when poll reach delay offset jitter
*127.127.1.0 127.127.1.0 10 l 4 64 377 0.000 0.000 0.008
10.1.1.111 127.127.1.0 16 u 594 1024 0 0.000 0.000 4000.00
synchronised to local net at stratum 11
time correct to within 11 ms
polling server every 64 s
Current time in UTC is : Tue Feb 17 18:40:42 UTC 2009
Current time in America/New_York is : Tue Feb 17 13:40:42 EST 2009
admin:ntpd (pid 7545) is running...
Right, but is it the same time on Pub and Sub?
here is the PUB
admin:utils ntp status
ntpd (pid 18702) is running...
127.127.1.0 127.127.1.0 10 l 45 64 3 0.000 0.000 0.004
10.1.1.44 .LOCL. 1 u 5 64 3 0.451 -350471 32.610
unsynchronised
time server re-starting
polling server every 16 s
Current time in UTC is : Tue Feb 17 20:38:07 UTC 2009
Current time in America/New_York is : Tue Feb 17 15:38:07 EST 2009
