Time is uncorrect on IPhone
I have CUCM 7 (Publisher and Subscriber) i set the timezone on both the Servers to Asia\Kuwait
and i also set the Data/Time Group in CUCM to Saudi arabia-( GMT +03:00)kuwait,
but on my Cisco IP Phones its showing 15 Mints forward from the standard time,
I access the server which the phone register in and execute the command (utils ntp status) the result is same phone time
how can i chnge it.
admin:utils ntp status
ntpd (pid 6830) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     LOCAL(0)        10 l   22   64  377    0.000    0.000   0.004
synchronised to local net at stratum 11
   time correct to within 12 ms
   polling server every 64 s
Current time in UTC is : Tue May 25 07:47:59 UTC 2010
Current time in Asia/Riyadh is : Tue May 25 10:47:59 AST 2010
Please guide me to sort out this issue
Al-kaff
1 ACCEPTED SOLUTION
Silver
Re: Time is uncorrect on IPhone
do you have any IOS router that you can configure as NTP Server and get your CUCM sync with it.
Otherwise, you can sync your cucm to any other type of NTP server or even external server.
thanks
- abu
Silver
thanks
- abu
I have core 4500E, i configure the time and date manuly
command
#ntp master
than I add ntp referance core ip address in callmanager
but nothing happening I do'nt known if this command ntp master is enough.
Hall of Fame Super Red
Hi Al-kaff,
NTP Servers
Ensure that external NTP server is stratum 9 or higher (1-9). To add, delete, or modify an external NTP server, follow this procedure:
Note You can only configure the NTP server settings on the first node or publisher.
Procedure
Step 1 From the Cisco Unified Communications Operating System Administration window, navigate to Settings>NTP Servers.
The NTP Server Settings window displays.
Step 2 You can add, delete, or modify an NTP server:
•To delete an NTP server, check the check box in front of the appropriate server and click Delete.
•To add an NTP server, click Add, enter the hostname or IP address, and then click Save.
•To modify an NTP server, click the IP address, modify the hostname or IP address, and then click Save.
Note Any change that you make to the NTP servers can take up to 5 minutes to complete. Whenever you make any change to the NTP servers, you must refresh the window to display the correct status.
Step 3 To refresh the NTP Server Settings window and display the correct status, choose Settings>NTP.
Note After deleting, modifying, or adding the NTP server, you must restart all other nodes in the cluster for the changes to take affect.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_0_1/cucos/iptpch4.html#wp1042131
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hi rob
I added the core IP on ntp setting from cisco Unified OS Administrator windows, but after reset the node time show now forword 3 hours.
the on the core switch is correct. when i show the ntp association there is filterror, what is the meaning of that.
ELC-CORE-1#sh ntp associations de
127.127.7.1 configured, our_master, sane, valid, stratum 14
ref ID 127.127.7.1, time CFA6D16A.6EFB20A6 (22:44:58.433 UTC Tue May 25 2010)
our mode active, peer mode passive, our poll intvl 64, peer poll intvl 64
root delay 0.00 msec, root disp 0.00, reach 377, sync dist 0.015
delay 0.00 msec, offset 0.0000 msec, dispersion 0.02
precision 2**18, version 3
org time CFA6D16A.6EFB20A6 (22:44:58.433 UTC Tue May 25 2010)
rcv time CFA6D16A.6EFB20A6 (22:44:58.433 UTC Tue May 25 2010)
xmt time CFA6D16A.6EFAFF18 (22:44:58.433 UTC Tue May 25 2010)
filtdelay =     0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filtoffset =    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
filterror =     0.02    0.99    1.97    2.94    3.92    4.90    5.87    6.85
Reference clock status:  Running normally
Timecode:
Problem solved. Thanks for all the help and suggestions
I change the Time Zone on my Callmanager to [GMT Standerd/daylight Time -(GMT) Greenwich]
It was saudi Arabi Standerd Time (GMT +03) Kuwait, that is whay showing forwrod 3 hours
Thanks Again
586
