Time issue on CUCM 7.0
Dear
i have cucm 7.0 , i did time + 3 , after one day the time changed automatically to wrong time ,  i did configure  time on OS page also when i choose 2013 instead of 2005 , it is return back to 2005 .
the customer doesnt want to configure NTP to solve this issue so how to solve this without configuring NTP ???
thanks
Silver
Why does the customer not want to run NTP?  NTP is very important for many CUCM processes.
becasue right now the customer doesnt have a any  windows server to run NTP
so the best solution run NTP ?
Re: Time issue on CUCM 7.0
NTP can be configured on Cisco router , then Cisco router will be your NTP server and this will be good for your issue. Please find the below information
#ntp source loopback 0
#ntp master 1
Then configure the time on your router based on your timezone.Go to CUCM -operating system-NTP servers-type the Loopback interface.
Thank you
please rate all useful information
Dear Islam
thanks for ur reply
i dont have loopback interface , how it will be the configuration exactly ? regarding timezone commands ?
please send to me the exactly configuration i need to put on router ?
thanks
itis not interface command . it is a global configuration command:
#clock set 20:00:00 aug 26 2010
R1(config)#ntp master 1
1-The request to configure the loopback , this is because loopback is stable interface and up every time .configuration as below
(conf)#interface loopbac0
(conf)#ip address 10.10.10.5 255.255.255.0
do not do no shut , because as i told you this interfce is up everytime.
for timezone configuration  , i will give you an exampla
(conf)#clock timezone PST -8     (where PST any name for your timezone) & -8 is your timezone offset.
(conf)#clock summertime PST recurring
you can also use the commands which MR/Baskaranm share with you for clock set commands.
Thank you
please rate all useful infomration
150
